Posts: 107 Threads: 19 Likes Received: 16 in 16 posts Likes Given: 28 Joined: Jan 2023 Reputation: 0 I figured I'd post here instead of cluttering up the dedicated boards with stuff I'm usually wrong about...lol I have a 2.5 inch that was flying great and had fairly solid FPV. But I was guessing at the channels and being a dummy didn't know you can simply match what's in beta flight to the chart in the PDF manual for the quad. Instead, I ended up updating the FC to the latest firmware. I was able to get the VTX tables into betaflight. And know what channel I'm on. Unfortunately, this didn't work out very well since for some reason the channel that I'm on in beta flight does not match the one in my goggles. For example, if I'm on R-6 in beta flight I won't be able to get FPV through that in my goggles. Instead I'll have to go to something bizarre like B-3... I don't know. Even more unfortunate I didn't do a CLI dump back up instead choosing to do a settings back up through beta flight as well as a diff all CLI dump. It seems that some of my PID values were not successfully transferred. These were the ones set by the manufacturer. And honestly the quad flew fantastic the way it was set up (pnp). Can the wrong (even stock beta flight) PID values introduce excess vibrations/ oscillations enough to dump a bunch of noise and interference into the VTX? I can't get the quad 50 ft away from me without completely losing visual... Can't even arm it and take off without heavy noise and breakup. I've tried just about everything recommended in other topics including a full breakdown and checking of all wires and connectors. But the issue persists. It even seems to be affecting my RX connection. Unfortunately, I'm unable to grab some footage through the DVR because the only SIM card on hand is a 64 and my goggles only support 32 max. So the quad has become unflyable through FPV and flies a little like crap through LOS. I know nothing about setting PIDs or the logic behind them. And yes, I've watched Bardwell's and a couple of other guys tutorials... Not that I would know if that is truly what's causing the issue. • Posts: 163 Threads: 7 Likes Received: 58 in 45 posts Likes Given: 33 Joined: Jan 2021 Reputation: 0 My guess would be that your goggles are on the wrong channel as you can only get about 50ft. Don't use the auto tune on your goggles it will often be wrong. Look at the betaflight chanel and manually set your goggles to that. If still having problems with video it may be a damaged antenna. Failing all that post a dump file here and someone can check it for you. Also what model is it? Someone should have a oem backup for you. • Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 what quad pnp do you use? from what version did you update to which one? what pid values do you have? pids can cause noise, but that means a worse image not unflyable. • Posts: 107 Threads: 19 Likes Received: 16 in 16 posts Likes Given: 28 Joined: Jan 2023 Reputation: 0 It's an LDARC AK123 Went from. 4.0.3 to 4.4.0 I've tried every channel that my goggles pick up since as I stated, the goggles don't seem to match up what channel the VTX is set to. So if I'm on Band A channel 4 on the VTX, on the goggles that channel is just static...then I'll scroll to a random band and channel and it'll give me a perfect feed. But as soon as I arm I get tons of noise. If I take off I start to get breakup and if I fly out I'll start to get black cut outs. The auto search on my goggles is trash just to use so I never do. I'd love to get back to 4.0.3 (which I have) BUT with the original manufacturer settings. Even if that means changing channels through the CLI. As on that firmware I can't even control the VTX through OSD and the VTX button gets disabled if I'm wired for IRC (it comes pre-wired). My antenna looks fine as it has an odd seal on the UHL connector I've never seen before (almost looks like clear heat shrink) none of the wire protrudes from the canopy only the pole(?) And it looks like the day it came out the box. I'm really at my wits end with this. Since I can't find any fault with the hardware. Unless it's just the VTX taking a crap from heat? I'm a beginner so I spend more time walking to find my quad than I do flying...lol • Posts: 107 Threads: 19 Likes Received: 16 in 16 posts Likes Given: 28 Joined: Jan 2023 Reputation: 0 Mind you I know next to nothing about this stuff. So the PIDs may actually be as they were by the manufacturer. All I remember is that the PID MODE must have been on eithr RP or RPY because I remember the sliders having color. Now MODE is on OFF # # dump # version # Betaflight / STM32F411 (S411) 4.4.0 Mar 19 2023 / 18:04:43 (4605309d8) MSP API: 1.45 # config: YES # start the command batch batch start board_name MATEKF411 manufacturer_id MTKS # name: AK123 # resources resource BEEPER 1 B02 resource MOTOR 1 B04 resource MOTOR 2 B05 resource MOTOR 3 B06 resource MOTOR 4 B07 resource MOTOR 5 B03 resource MOTOR 6 B10 resource MOTOR 7 NONE resource MOTOR 8 NONE resource LED_STRIP 1 A08 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE resource INVERTER 1 NONE resource INVERTER 2 NONE resource INVERTER 3 NONE resource INVERTER 4 NONE resource INVERTER 5 NONE resource INVERTER 6 NONE resource INVERTER 7 NONE resource INVERTER 8 NONE resource INVERTER 9 NONE resource INVERTER 10 NONE resource INVERTER 11 NONE resource INVERTER 12 NONE resource I2C_SCL 1 B08 resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SDA 1 B09 resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource LED 1 C13 resource LED 2 C14 resource LED 3 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 NONE resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 NONE resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 NONE resource ESCSERIAL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource BARO_CS 1 NONE resource BARO_EOC 1 NONE resource BARO_XCLR 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource OSD_CS 1 B12 resource GYRO_EXTI 1 A01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A04 resource GYRO_CS 2 NONE resource USB_DETECT 1 C15 resource PULLUP 1 NONE resource PULLUP 2 NONE resource PULLUP 3 NONE resource PULLUP 4 NONE resource PULLDOWN 1 NONE resource PULLDOWN 2 NONE resource PULLDOWN 3 NONE resource PULLDOWN 4 NONE # timer timer A03 AF3 # pin A03: TIM9 CH2 (AF3) timer B04 AF2 # pin B04: TIM3 CH1 (AF2) timer B05 AF2 # pin B05: TIM3 CH2 (AF2) timer B06 AF2 # pin B06: TIM4 CH1 (AF2) timer B07 AF2 # pin B07: TIM4 CH2 (AF2) timer B03 AF1 # pin B03: TIM2 CH2 (AF1) timer B10 AF1 # pin B10: TIM2 CH3 (AF1) timer A00 AF2 # pin A00: TIM5 CH1 (AF2) timer A02 AF2 # pin A02: TIM5 CH3 (AF2) timer A08 AF1 # pin A08: TIM1 CH1 (AF1) # dma dma SPI_MOSI 1 NONE dma SPI_MOSI 2 NONE dma SPI_MOSI 3 NONE dma SPI_MISO 1 NONE dma SPI_MISO 2 NONE dma SPI_MISO 3 NONE dma SPI_TX 1 NONE dma SPI_TX 2 NONE dma SPI_TX 3 NONE dma SPI_RX 1 NONE dma SPI_RX 2 NONE dma SPI_RX 3 NONE dma ADC 1 1 # ADC 1: DMA2 Stream 4 Channel 0 dma ADC 2 NONE dma ADC 3 NONE dma UART_TX 1 NONE dma UART_TX 2 NONE dma UART_TX 3 NONE dma UART_TX 4 NONE dma UART_TX 5 NONE dma UART_TX 6 NONE dma UART_TX 7 NONE dma UART_TX 8 NONE dma UART_RX 1 NONE dma UART_RX 2 NONE dma UART_RX 3 NONE dma UART_RX 4 NONE dma UART_RX 5 NONE dma UART_RX 6 NONE dma UART_RX 7 NONE dma UART_RX 8 NONE dma pin A03 NONE dma pin B04 0 # pin B04: DMA1 Stream 4 Channel 5 dma pin B05 0 # pin B05: DMA1 Stream 5 Channel 5 dma pin B06 0 # pin B06: DMA1 Stream 0 Channel 2 dma pin B07 0 # pin B07: DMA1 Stream 3 Channel 2 dma pin B03 0 # pin B03: DMA1 Stream 6 Channel 3 dma pin B10 0 # pin B10: DMA1 Stream 1 Channel 3 dma pin A00 0 # pin A00: DMA1 Stream 2 Channel 6 dma pin A02 0 # pin A02: DMA1 Stream 0 Channel 6 dma pin A08 0 # pin A08: DMA2 Stream 6 Channel 0 # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature RX_SERIAL feature SOFTSERIAL feature TELEMETRY feature LED_STRIP feature OSD # serial serial 20 1 115200 57600 0 115200 serial 0 8192 115200 57600 0 115200 serial 1 64 115200 57600 0 115200 # mixer mixer QUADX mmix reset # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon -RX_LOST beacon RX_SET # map map AETR1234 # led led 0 6,12::CTOBVIW:0 led 1 7,12::CTOBVIW:0 led 2 8,12::CTOBVIW:0 led 3 9,12::CTOBVIW:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1700 2100 0 0 aux 1 1 1 1200 1600 0 0 aux 2 13 2 1800 2100 0 0 aux 3 47 1 900 1200 0 0 aux 4 0 0 900 900 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BAND_A A CUSTOM 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BAND_B B CUSTOM 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BAND_C C CUSTOM 5705 5685 5665 5645 5885 5905 5925 5945 vtxtable band 4 BAND_D D CUSTOM 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 BAND_E E CUSTOM 5362 5400 5436 5473 5510 5547 5584 5620 vtxtable band 6 BAND_F F CUSTOM 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 4 vtxtable powervalues 0 25 100 200 vtxtable powerlabels 0 25 100 200 # vtx vtx 0 0 0 0 0 900 900 vtx 1 0 0 0 0 900 900 vtx 2 0 0 0 0 900 900 vtx 3 0 0 0 0 900 900 vtx 4 0 0 0 0 900 900 vtx 5 0 0 0 0 900 900 vtx 6 0 0 0 0 900 900 vtx 7 0 0 0 0 900 900 vtx 8 0 0 0 0 900 900 vtx 9 0 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set gyro_hardware_lpf = NORMAL set gyro_lpf1_type = PT1 set gyro_lpf1_static_hz = 250 set gyro_lpf2_type = PT1 set gyro_lpf2_static_hz = 500 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = AUTO set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_count = 3 set dyn_notch_q = 300 set dyn_notch_min_hz = 100 set dyn_notch_max_hz = 600 set gyro_lpf1_dyn_min_hz = 250 set gyro_lpf1_dyn_max_hz = 500 set gyro_lpf1_dyn_expo = 5 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 25 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -59,-13,-88,1 set baro_bustype = I2C set baro_spi_device = 0 set baro_i2c_device = 1 set baro_i2c_address = 0 set baro_hardware = NONE set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rssi_src_frame_lpf_period = 30 set rssi_smoothing = 125 set rc_smoothing = ON set rc_smoothing_auto_factor = 30 set rc_smoothing_auto_factor_throttle = 30 set rc_smoothing_setpoint_cutoff = 0 set rc_smoothing_feedforward_cutoff = 0 set rc_smoothing_throttle_cutoff = 0 set rc_smoothing_debug_axis = ROLL set fpv_mix_degrees = 25 set max_aux_channels = 14 set serialrx_provider = CRSF set serialrx_inverted = OFF set sbus_baud_fast = OFF set crsf_use_negotiated_baud = OFF set airmode_start_throttle_percent = 55 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set msp_override_channels_mask = 0 set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 550 set dshot_burst = AUTO set dshot_bidir = OFF set dshot_edt = OFF set dshot_bitbang = OFF set dshot_bitbang_timer = AUTO set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT300 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set motor_output_reordering = 0,1,2,3,4,5,6,7 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 15 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = AUTO-LAND set failsafe_recovery_delay = 10 set failsafe_stick_threshold = 30 set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set bat_capacity = 0 set vbat_max_cell_voltage = 430 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 330 set vbat_warning_cell_voltage = 350 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_display_lpf_period = 30 set vbat_sag_lpf_period = 2 set ibat_lpf_period = 10 set vbat_duration_for_warning = 0 set vbat_duration_for_critical = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 210 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = ON set mixer_type = LEGACY set crashflip_motor_percent = 0 set crashflip_expo = 35 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 25 set imu_process_denom = 2 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = UBLOX set gps_sbas_mode = NONE set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_mode = AIRBORNE set gps_ublox_use_galileo = OFF set gps_set_home_point_once = OFF set gps_use_3d_speed = OFF set gps_sbas_integrity = OFF set gps_rescue_min_start_dist = 30 set gps_rescue_alt_mode = MAX_ALT set gps_rescue_initial_climb = 10 set gps_rescue_ascend_rate = 500 set gps_rescue_return_alt = 30 set gps_rescue_ground_speed = 500 set gps_rescue_pitch_angle_max = 40 set gps_rescue_roll_mix = 150 set gps_rescue_descent_dist = 20 set gps_rescue_descend_rate = 100 set gps_rescue_landing_alt = 4 set gps_rescue_throttle_min = 1100 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1275 set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY set gps_rescue_min_sats = 8 set gps_rescue_allow_arming_without_fix = OFF set gps_rescue_throttle_p = 15 set gps_rescue_throttle_i = 15 set gps_rescue_throttle_d = 15 set gps_rescue_velocity_p = 8 set gps_rescue_velocity_i = 30 set gps_rescue_velocity_d = 20 set gps_rescue_yaw_p = 20 set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 2 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set simplified_gyro_filter = ON set simplified_gyro_filter_multiplier = 100 set tlm_inverted = OFF set tlm_halfduplex = ON set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set telemetry_disabled_voltage = OFF set telemetry_disabled_current = OFF set telemetry_disabled_fuel = OFF set telemetry_disabled_mode = OFF set telemetry_disabled_acc_x = OFF set telemetry_disabled_acc_y = OFF set telemetry_disabled_acc_z = OFF set telemetry_disabled_pitch = OFF set telemetry_disabled_roll = OFF set telemetry_disabled_heading = OFF set telemetry_disabled_altitude = OFF set telemetry_disabled_vario = OFF set telemetry_disabled_lat_long = OFF set telemetry_disabled_ground_speed = OFF set telemetry_disabled_distance = OFF set telemetry_disabled_esc_current = ON set telemetry_disabled_esc_voltage = ON set telemetry_disabled_esc_rpm = ON set telemetry_disabled_esc_temperature = ON set telemetry_disabled_temperature = OFF set telemetry_disabled_cap_used = ON set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set ledstrip_brightness = 100 set osd_units = METRIC set osd_warn_bitmask = 8191 set osd_rssi_alarm = 20 set osd_link_quality_alarm = 80 set osd_rssi_dbm_alarm = -60 set osd_rsnr_alarm = 4 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_distance_alarm = 0 set osd_esc_temp_alarm = 0 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_logo_on_arming = OFF set osd_logo_on_arming_duration = 5 set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 354 set osd_rssi_pos = 2132 set osd_link_quality_pos = 2100 set osd_link_tx_power_pos = 234 set osd_rssi_dbm_pos = 234 set osd_rsnr_pos = 234 set osd_tim_1_pos = 341 set osd_tim_2_pos = 2421 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 2373 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 2090 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 2254 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_wh_drawn_pos = 234 set osd_motor_diag_pos = 234 set osd_craft_name_pos = 2389 set osd_pilot_name_pos = 234 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_flight_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 2119 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 14729 set osd_avg_cell_voltage_pos = 2405 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 2347 set osd_nheading_pos = 234 set osd_up_down_reference_pos = 205 set osd_ready_mode_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_esc_rpm_freq_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234 set osd_core_temp_pos = 234 set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_rate_profile_name_pos = 234 set osd_pid_profile_name_pos = 234 set osd_profile_name_pos = 234 set osd_rcchannels_pos = 234 set osd_camera_frame_pos = 35 set osd_efficiency_pos = 234 set osd_total_flights_pos = 234 set osd_aux_pos = 234 set osd_sys_goggle_voltage_pos = 234 set osd_sys_vtx_voltage_pos = 234 set osd_sys_bitrate_pos = 234 set osd_sys_delay_pos = 234 set osd_sys_distance_pos = 234 set osd_sys_lq_pos = 234 set osd_sys_goggle_dvr_pos = 234 set osd_sys_vtx_dvr_pos = 234 set osd_sys_warnings_pos = 234 set osd_sys_vtx_temp_pos = 234 set osd_sys_fan_speed_pos = 234 set osd_stat_bitmask = 14124 set osd_profile = 1 set osd_profile_1_name = - set osd_profile_2_name = - set osd_profile_3_name = - set osd_gps_sats_show_hdop = OFF set osd_displayport_device = AUTO set osd_rcchannels = -1,-1,-1,-1 set osd_camera_frame_width = 24 set osd_camera_frame_height = 11 set osd_stat_avg_cell_value = OFF set osd_framerate_hz = 12 set osd_menu_background = TRANSPARENT set osd_aux_channel = 1 set osd_aux_scale = 200 set osd_aux_symbol = 65 set osd_canvas_width = 30 set osd_canvas_height = 13 set osd_craftname_msgs = OFF set system_hse_mhz = 8 set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = 108MHZ set pwr_on_arm_grace = 5 set enable_stick_arming = OFF set vtx_band = 6 set vtx_channel = 8 set vtx_power = 2 set vtx_low_power_disarm = UNTIL_FIRST_ARM set vtx_softserial_alt = OFF set vtx_freq = 5917 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = NOMINAL set max7456_spi_bus = 2 set max7456_preinit_opu = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_msp_fonts = 0,0,0,0 set displayport_msp_use_device_blink = OFF set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set led_inversion = 0 set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0 set rcdevice_feature = 0 set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW180 set gyro_1_align_roll = 0 set gyro_1_align_pitch = 0 set gyro_1_align_yaw = 1800 set gyro_2_bustype = SPI set gyro_2_spibus = 0 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = CW0 set gyro_2_align_roll = 0 set gyro_2_align_pitch = 0 set gyro_2_align_yaw = 0 set i2c1_pullup = OFF set i2c1_clockspeed_khz = 800 set i2c2_pullup = OFF set i2c2_clockspeed_khz = 800 set i2c3_pullup = OFF set i2c3_clockspeed_khz = 800 set mco2_on_pc9 = OFF set scheduler_relax_rx = 1 set scheduler_relax_osd = 1 set serialmsp_halfduplex = OFF set timezone_offset_minutes = 0 set rpm_filter_harmonics = 3 set rpm_filter_q = 500 set rpm_filter_min_hz = 100 set rpm_filter_fade_range_hz = 50 set rpm_filter_lpf_hz = 150 set stats_min_armed_time_s = -1 set stats_total_flights = 0 set stats_total_time_s = 0 set stats_total_dist_m = 0 set craft_name = AK123 set pilot_name = Mugen_G set altitude_source = DEFAULT set altitude_prefer_baro = 100 set altitude_lpf = 300 set altitude_d_lpf = 100 set box_user_1_name = - set box_user_2_name = - set box_user_3_name = - set box_user_4_name = - profile 0 # profile 0 set profile_name = - set dterm_lpf1_dyn_min_hz = 75 set dterm_lpf1_dyn_max_hz = 150 set dterm_lpf1_dyn_expo = 5 set dterm_lpf1_type = PT1 set dterm_lpf1_static_hz = 75 set dterm_lpf2_type = PT1 set dterm_lpf2_static_hz = 150 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_sag_compensation = 0 set pid_at_min_throttle = ON set anti_gravity_gain = 80 set anti_gravity_cutoff_hz = 5 set anti_gravity_p_gain = 100 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set iterm_relax = RP set iterm_relax_type = GYRO set iterm_relax_cutoff = 15 set iterm_windup = 85 set iterm_limit = 400 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 100 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 25 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 51 set i_pitch = 84 set d_pitch = 46 set f_pitch = 125 set p_roll = 47 set i_roll = 80 set d_roll = 40 set f_roll = 120 set p_yaw = 45 set i_yaw = 80 set d_yaw = 0 set f_yaw = 90 set angle_level_strength = 30 set horizon_level_strength = 30 set horizon_transition = 85 set level_limit = 25 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set use_integrated_yaw = OFF set integrated_yaw_relax = 200 set d_min_roll = 30 set d_min_pitch = 34 set d_min_yaw = 0 set d_max_gain = 37 set d_max_advance = 20 set motor_output_limit = 100 set auto_profile_cell_count = 0 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 set thrust_linear = 0 set transient_throttle_limit = 0 set feedforward_transition = 0 set feedforward_averaging = OFF set feedforward_smooth_factor = 25 set feedforward_jitter_factor = 7 set feedforward_boost = 15 set feedforward_max_rate_limit = 90 set dyn_idle_min_rpm = 0 set dyn_idle_p_gain = 50 set dyn_idle_i_gain = 50 set dyn_idle_d_gain = 50 set dyn_idle_max_increase = 150 set level_race_mode = OFF set simplified_pids_mode = RPY set simplified_master_multiplier = 100 set simplified_i_gain = 100 set simplified_d_gain = 100 set simplified_pi_gain = 100 set simplified_dmax_gain = 100 set simplified_feedforward_gain = 100 set simplified_pitch_d_gain = 100 set simplified_pitch_pi_gain = 100 set simplified_dterm_filter = ON set simplified_dterm_filter_multiplier = 100 set tpa_mode = D set tpa_rate = 65 set tpa_breakpoint = 1350 rateprofile 0 # rateprofile 0 set rateprofile_name = - set thr_mid = 50 set thr_expo = 0 set rates_type = ACTUAL set quickrates_rc_expo = OFF set roll_rc_rate = 7 set pitch_rc_rate = 7 set yaw_rc_rate = 7 set roll_expo = 0 set pitch_expo = 0 set yaw_expo = 0 set roll_srate = 67 set pitch_srate = 67 set yaw_srate = 67 set throttle_limit_type = SCALE set throttle_limit_percent = 50 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 set roll_level_expo = 0 set pitch_level_expo = 0 # end the command batch batch end # diff all # version # Betaflight / STM32F411 (S411) 4.4.0 Mar 19 2023 / 18:04:43 (4605309d8) MSP API: 1.45 # config: YES # start the command batch batch start # reset configuration to default settings defaults nosave board_name MATEKF411 manufacturer_id MTKS mcu_id 003d00533437511831393434 signature # name: AK123 # feature feature -AIRMODE feature -ANTI_GRAVITY feature LED_STRIP # serial serial 0 8192 115200 57600 0 115200 serial 1 64 115200 57600 0 115200 # beacon beacon RX_SET # led led 0 6,12::CTOBVIW:0 led 1 7,12::CTOBVIW:0 led 2 8,12::CTOBVIW:0 led 3 9,12::CTOBVIW:0 # aux aux 0 0 0 1700 2100 0 0 aux 1 1 1 1200 1600 0 0 aux 2 13 2 1800 2100 0 0 aux 3 47 1 900 1200 0 0 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BAND_A A CUSTOM 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BAND_B B CUSTOM 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BAND_C C CUSTOM 5705 5685 5665 5645 5885 5905 5925 5945 vtxtable band 4 BAND_D D CUSTOM 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 BAND_E E CUSTOM 5362 5400 5436 5473 5510 5547 5584 5620 vtxtable band 6 BAND_F F CUSTOM 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 4 vtxtable powervalues 0 25 100 200 vtxtable powerlabels 0 25 100 200 # master set acc_calibration = -59,-13,-88,1 set fpv_mix_degrees = 25 set airmode_start_throttle_percent = 55 set motor_pwm_protocol = DSHOT300 set failsafe_procedure = AUTO-LAND set ibata_scale = 210 set yaw_motors_reversed = ON set osd_vbat_pos = 354 set osd_rssi_pos = 2132 set osd_link_quality_pos = 2100 set osd_tim_1_pos = 341 set osd_tim_2_pos = 2421 set osd_flymode_pos = 2373 set osd_vtx_channel_pos = 2090 set osd_ah_sbar_pos = 2254 set osd_craft_name_pos = 2389 set osd_altitude_pos = 2119 set osd_warnings_pos = 14729 set osd_avg_cell_voltage_pos = 2405 set osd_disarmed_pos = 2347 set osd_canvas_width = 30 set osd_canvas_height = 13 set vtx_band = 6 set vtx_channel = 8 set vtx_power = 2 set vtx_low_power_disarm = UNTIL_FIRST_ARM set vtx_freq = 5917 set gyro_1_align_yaw = 1800 set craft_name = AK123 set pilot_name = Mugen_G profile 0 # profile 0 set iterm_rotation = ON set iterm_relax_type = GYRO set acro_trainer_angle_limit = 25 set p_pitch = 51 set p_roll = 47 set f_yaw = 90 set angle_level_strength = 30 set horizon_level_strength = 30 set horizon_transition = 85 set level_limit = 25 profile 1 profile 2 profile 3 # restore original profile selection profile 0 rateprofile 0 # rateprofile 0 set throttle_limit_type = SCALE set throttle_limit_percent = 50 rateprofile 1 rateprofile 2 rateprofile 3 # restore original rateprofile selection rateprofile 0 # save configuration save # • Posts: 4,073 Threads: 75 Likes Received: 2,549 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 24-Mar-2023, 01:40 AM (This post was last modified: 24-Mar-2023, 01:50 AM by Lemonyleprosy.) I couldn’t find a proper manufacturer’s dump or diff all, however, here is a link to the AK123 manual: http://15736572.s21d-15.faiusrd.com/61/A...ouPwAU.pdf Page 8 and down shows every betaflight setting they set from the factory. Page 9 shows factory pids. You’ll want to flash back to bf 4.0.3 prior to following their settings. Regarding your vtx, it sounds like you either did not set up your vtx in the ports tab correctly, and/or you didn’t upload the correct vtx table, (and it sounds like you might be in pit mode or 25mw- without the right port settings and vtx table, changing the value on the vtx tab in betaflight won’t actually change anything). Page 3 on that manual has the vtx table, and page 8 goes over your port settings. Edit- page 3 also tells you how to read the leds on your vtx, so that you can verify what band/channel/power level you’re actually on. Edit edit- the page numbers I’m referencing are the page numbers on the bottom of each page, not the pdf page number. I didn’t take into account the cover page. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 2,687 Threads: 83 Likes Received: 1,429 in 1,073 posts Likes Given: 854 Joined: Apr 2022 Reputation: 43 24-Mar-2023, 02:13 AM (This post was last modified: 24-Mar-2023, 02:13 AM by Pathfinder075.) So it's a VTX Betaflight issue, not a tuning issue. You should change your topic title to something like "VTX Issues, need firmware/dump". Your FC is a LDARC F411E12A AIO Flight Controller (F4 + 12A ESC) Your VTX is a LDARC KKT-VTX200 From what I can gather you need to put 4.0.3 back on it and find a dump/diff for it. Quote:KINKONG/LDARC AK123 122mm 3S 3 Inch Toothpick FPV Racing Drone PNP/BNF F4 FC 12A Blheli_S ESC 25~200mW VTX Runcam Nano2 Cam Specification: Brand name: LDARC Item name: AK123 122mm 3S 3 Inch Toothpick FPV Racing Drone Wheelbase: 122mm Propeller: 75mm Racer (1.5 hole) Motor: XT1103-6100KV (1.5mm shaft) Camera: Runcam Nano2 FC: F411E12A (MATEKF411) ESC: 4 IN 1 12A Blheli_S (G-H-30) VTX: 0/25/100/200 48CH IRC Tramp Receiver: AC2000 DUAL-CORE TRI-MODE(S-FHSS, D16 non-E, D16 EU-LBT) ONLY BNF Version Included Battery: 11.4V 300mAh 30C Weight(without battery, receiver and bumper): 55g Package Included: 1 x AK123 122mm 3S 3 Inch FPV Racing Drone 1 x 11.4V 300mAh 30C Battery 10 x CW 75mm 2-blade Propeller 10 x CW 75mm 2-blade Propeller So my suggestion is to put 4.0.3 back on it. It flew ok on 4.0.3, as you said, so put 4.0.3 back on it. Everyone nowadays has such a hard on for putting 4.4 on everything and most of the time it just breaks older quads. Don't fix what isn't broken. :/ So if it was me, I might be tempted to try 4.2.11 as well. I have a drone that uses an FrSky D8/D16 receiver that won't work on 4.3, but works fine on 4.2.11, so maybe try that too. But mainly just put 4.0.3 back on. I think what you've done with your vtx somehow is enter the channel data manually and you've basically changed it so say R8 no longer corresponds to the frequency R8 should be on. So start by flashing a fresh copy of the original firmware back on. See if that fixes the VTX table. Another possibility if you want to try it. Try putting Quicksilver on it. There is a Matekf411.brushless target. It might work out of the box without you needing to mess with it too much. Try Not, Do or Do Not - Yoda • Posts: 107 Threads: 19 Likes Received: 16 in 16 posts Likes Given: 28 Joined: Jan 2023 Reputation: 0 Thanks guys. I'll try everything you listed. @pathfinder...as I stated, it's the reason I put it in beginners topic. It's because I'm new and am basically taking guesses at what's wrong. The only thing that's changed is the firmware (and as others have mentioned that doesn't cause VTX issues) The only thing that I can visually theorized has changed is the PIDs so that's what I posted it as. And yes I reconfigured the channel numbers to match what's in the manual for the AK123. I was under the impression that that's what I was supposed to do since the standard IRC tramp tables have different power levels and channels not found on the quads PDF manual chart? I put 4.0.3 back on it and switched to 4.4.0 back and forth. Since I have a settings back up for the former as well as the later including diff all. But neither seem to put the PIDs back to where they were originally. And no I'm with you on that, I can't stand updating even drivers for devices...lol only do it as a last resort... But having no idea how to manually set up a VTX through the CLI and having no guidance, I decided to update the firmware to be able to just load the tables which I couldn't even do before... Or at least did not know how without having beta flight practically do it for me. @lemonyleprosy I have the manual but never got that far into it. Thank you for pointing that out. Hopefully that'll get everything back to normal. I was starting to lose hope (hopefully this will prove me wrong) and had even begun pinching components from it... Like the buzzer which I put on another quad. That's flying beautifully... But I still got love for the AK123 because it looks like a toy and is/was a crazy little ripper even just in LOS • Posts: 4,073 Threads: 75 Likes Received: 2,549 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 It sounds like it’d be a fun bird to fly. Hopefully following the betaflight settings in the manual gets you sorted out. If it doesn’t, as Pathfinder said, quicksilver is an option. It’s ridiculously easy to set up, and flies great on defaults. Pathfinder or I can walk you through the setup if you decide to give it a shot. https://docs.bosshobby.com/ Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 its a mistake to copy paste settings between major releases. as example you can sett copy paste from 4.0.1 to 4.0.8 with no problem but you will get faults and complete different result for pids and filters if you copypaste from 4.0.2 to 4.1.1. a quad needs to be settup fresh, pids need to be adjusted for the particular version. if you like to try 4.4 again, just try out the defaults, they match okish for a wide range of quads. Posts: 978 Threads: 73 Likes Received: 347 in 260 posts Likes Given: 157 Joined: Dec 2021 Reputation: 19 As a generic point, you cannot trust some VTX data tables using the Letter/Number (A7, B2) channel ident, as there was a long period (maybe still around, I no longer buy Analogue to know) when there was NO STANDARD coming from the various China sources!!! I have units where "A" band is "C" band, and reversed order! This was particularly but not exclusively true of the various micro camera/vtx/antenna combos. I came across this quite a few years ago as I was buying and using at one time 5-10 units per month, so a LOT of differing makes/models passed through my hands. Some of those makes/models are still around today. This is a separate issue from the possible confusion of differing bands having some channels that so closely approach they might as well be the same. The ONLY way to be sure is to use the four figure (5745, etc) number. • Posts: 978 Threads: 73 Likes Received: 347 in 260 posts Likes Given: 157 Joined: Dec 2021 Reputation: 19 (24-Mar-2023, 03:21 AM)Mugen_G Wrote: And yes I reconfigured the channel numbers to match what's in the manual for the AK123. I was under the impression that that's what I was supposed to do since the standard IRC tramp tables have different power levels and channels not found on the quads PDF manual chart? Partly answered in my post above. I have units with only four bands, and some with eight bands, each with eight channels. Early "Inductrix" models only had one band of eight channels from their VTX, a state we are going back to with HD as for example HDZero, like most HD, needing greater bandwidth than analogue per channel, has the eight channels of race band, plus two from "F" band, one at least being not far enough away from race band channels to be at all useful. And that is ignoring varying worldwide legality, as for example in the UK only four of the race bands eight channels are within the legal range. • Posts: 107 Threads: 19 Likes Received: 16 in 16 posts Likes Given: 28 Joined: Jan 2023 Reputation: 0 24-Mar-2023, 05:02 PM (This post was last modified: 24-Mar-2023, 05:02 PM by Mugen_G.) (24-Mar-2023, 08:24 AM)BadRaven Wrote: Partly answered in my post above. I have units with only four bands, and some with eight bands, each with eight channels. Early "Inductrix" models only had one band of eight channels from their VTX, a state we are going back to with HD as for example HDZero, like most HD, needing greater bandwidth than analogue per channel, has the eight channels of race band, plus two from "F" band, one at least being not far enough away from race band channels to be at all useful. And that is ignoring varying worldwide legality, as for example in the UK only four of the race bands eight channels are within the legal range. Yup, confused the heck out of me. So I reloaded the international IRC Tramp tables and only adjusted the power levels. Now my channels match. But now I'm having a different issue... Grey screen FPV feed with OSD overlay present. I think I saw that issue addressed in a different post here in B questions... • Posts: 107 Threads: 19 Likes Received: 16 in 16 posts Likes Given: 28 Joined: Jan 2023 Reputation: 0 25-Mar-2023, 01:54 AM (This post was last modified: 25-Mar-2023, 01:54 AM by Mugen_G.) Well it seems I figured out the issue. It appears my camera is no longer among the living. I don't think the thin plastic canopy offers much protection against hard knocks... Because the camera itself doesn't have a single scratch on it. But I switched it for a foxier razor nano from a different quad and the issue seems to have resolved itself. Though i did return the PIDs to their factory settings... As many of them as I could anyway as some of them don't seem to be present in the betaflight 10 configurator Posts: 4,073 Threads: 75 Likes Received: 2,549 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 Glad you got it sorted out, how’s it flying? Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • |
