Parachute Drop From Mini Quad
So I have been thinking of making a rig to drop objects (like parachutes) from my mini quad. I have done this previously with a plane, where I just wired the servo to the receiver and assigned the channel to a switch. This would not work with a mini quad though, since all signals are sent through the iBus signal wire. How would I go about wiring the servo to my flight controller, and how would I set a certain switch to move the servo? Any help appreciated!
Check out "servo tilt" control. Does exactly what you want.
  Accessory Radiomaster Pocket gimbal drop! Bud13420 1 511 03-Jan-2024, 04:17 PM
Last Post: Alfonso Gordon
  bitrate drop down from 50 to 20 Ika 2 445 20-Apr-2022, 01:52 AM
Last Post: kafie1980
  Tutorial DIY Mini Rotary Tool - Drill || Grinder || Cutter || Polisher || - A2212 1000KV Brush sim_tcr 1 816 24-Dec-2021, 03:51 PM
Last Post: iFly4rotors
  Mamba F405 Mini MK2 - GPS on Softserial fishbowlfpv 13 8,667 07-Jul-2021, 06:07 AM
Last Post: president_kang
  Ever wanted to smash the SH*T out of ur quad? Rob Axel 2 657 20-Mar-2021, 01:51 AM
