27-May-2023, 01:02 PM
Full review: https://oscarliang.com/betafpv-pavo-pico-whoop-dji-o3/
defaults nosave
# Betaflight / STM32F405 (S405) 4.4.1 Apr 13 2023 / 06:44:52 (e43d591b2) MSP API: 1.45
# config: YES
# start the command batch
batch start
defaults nosave
board_name BETAFPVF405
manufacturer_id BEFH
mcu_id 002c00243431471539333635
signature
# name: Pavo Pico
feature TELEMETRY
serial 3 131073 115200 57600 0 115200
# beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
led 0 0,0::AB:0
led 1 1,0::AB:0
aux 0 0 0 1700 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 13 2 1700 2100 0 0
aux 3 35 2 1700 2100 0 0
# master
set gyro_lpf2_static_hz = 0
set dyn_notch_count = 0
set dyn_notch_q = 500
set gyro_lpf1_dyn_min_hz = 0
set acc_calibration = -20,5,-30,1
set baro_hardware = AUTO
set min_check = 1010
set serialrx_provider = CRSF
set blackbox_device = NONE
set dshot_idle_value = 550
set dshot_bidir = ON
set motor_output_reordering = 2,3,0,1,4,5,6,7
set align_board_roll = 180
set vbat_min_cell_voltage = 335
set vbat_warning_cell_voltage = 345
set ibata_scale = 750
set small_angle = 180
set deadband = 5
set yaw_deadband = 5
set osd_vbat_pos = 2561
set osd_rssi_pos = 192
set osd_link_quality_pos = 2496
set osd_rssi_dbm_pos = 2464
set osd_rsnr_pos = 160
set osd_tim_2_pos = 3629
set osd_flymode_pos = 3598
set osd_throttle_pos = 3566
set osd_crosshairs_pos = 2361
set osd_current_pos = 2592
set osd_craft_name_pos = 2582
set osd_warnings_pos = 14837
set debug_mode = GYRO_SCALED
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_freq = 0
set vcd_video_system = HD
set craft_name = Pavo Pico
# profile 0
set p_pitch = 66
set i_pitch = 89
set d_pitch = 51
set f_pitch = 131
set p_roll = 60
set i_roll = 81
set d_roll = 43
set p_yaw = 60
set i_yaw = 81
set d_min_roll = 43
set d_min_pitch = 51
set feedforward_jitter_factor = 10
set simplified_i_gain = 75
set simplified_d_gain = 145
set simplified_pi_gain = 135
set simplified_dmax_gain = 0
set simplified_pitch_d_gain = 105
set simplified_pitch_pi_gain = 105
set tpa_rate = 68
profile 1
profile 2
profile 3
rateprofile 1
rateprofile 2
rateprofile 3
# save configuration
