Omnibus Pro Corner X SRXL Telemetry Spektrum
Can someone help me on how I install and configure the FC Omnibus Pro Corner with the RX SPM4649T (Spektrum).
I can not make the telemetry work. I already tried everything (Uart1 tx1, Uart3 tx3, Uart6 tx6).
But by looking at these two manuals (FC and RX).I do not know which TX to connect and I do not know which command to give in the Betaflight CLI.
github.com/betaflight/betaflight/wiki/Spektrum-SPM4649T-SRXL-Telemetry-setup
github.com/betaflight/betaflight/wiki/Board---OMNIBUS-F4-Pro-Corners
*In TX1 it does not work and in RX1 it works without the telemetry!
For the Omnibus, you should be connected to UART 3 tx. Can you post pics of your ports, configuration and receiver screens in Betaflight
  GOKU F722 PRO V2 50A BLS 30X30 Stack (MPU6000) husafreak 2 184 03-Mar-2024, 05:09 PM
Last Post: husafreak
  Semi Newbie here - T-Motor F7 Pro Full Function Tonestire 9 1,507 19-Feb-2024, 07:23 AM
Last Post: MontyFPV
  Help Betaflight telemetry output smartport paulno 24 1,436 05-Oct-2023, 06:23 PM
  CRAZYBEE F4 PRO doe not get to DFU mode orangu 8 3,544 08-Aug-2023, 09:46 PM
Last Post: zomer
  Help T-Motor F7 Pro - Reciever priority (DJI) tfr33 4 543 01-Jul-2023, 08:30 PM
Last Post: Lemonyleprosy
