05-Dec-2023, 06:10 PM
Can you assume the mounting bolt size/spacing will be the same for the new motor if you match the numbers written on the side of the old motor?
Numbers on the Motors |
05-Dec-2023, 06:10 PM Can you assume the mounting bolt size/spacing will be the same for the new motor if you match the numbers written on the side of the old motor? 05-Dec-2023, 06:49 PM Nothings guaranteed, especially if from differing manufacturers, which you don't indicate. 05-Dec-2023, 07:06 PM 05-Dec-2023, 07:28 PM No, best to check the motor spec sheet. Typically whoop motors (1102 and smaller) will have three hole mount (M1.4 @6mm), micro motors 4 hole mount (m2 9x9mm) and mini motors (m3 16x16mm), but it could be different. 05-Dec-2023, 08:16 PM (05-Dec-2023, 07:28 PM)mstc Wrote: No, best to check the motor spec sheet. These are 9mm according to my measurement. I'll shop for that size and see what I find. Thanks. |
Very inconsistent motors/ARMING | tenaciousFPV | 7 | 130 | Today, 04:11 AM Last Post: husafreak | |
Why do higher voltage batteries need lower KV motors? | Eyes.fpv | 1 | 119 | 04-May-2024, 01:42 AM Last Post: SeismicCWave | |
Motors not responding to transmitter input(no airmode) | corwin | 1 | 91 | 22-Apr-2024, 05:07 PM Last Post: mstc | |
Beta95x V3 motors not start | kronk | 3 | 125 | 20-Apr-2024, 07:28 PM Last Post: kronk | |
BFC REORDER MOTORS NOT SPINNING | soky157 | 4 | 129 | 08-Apr-2024, 05:38 AM Last Post: Pathfinder075 |
