Threads: 172
Likes Given: 4,753
103 how is the powerdistribution board connected to the fc?
it seems you have voltage sensing cable attached in blue, maybe there is no connection to an fc-osd?
you will need to activate runcams osd by an adapter
Threads: 595
Likes Received: 9,037 in 6,688 posts
Likes Given: 1,428
796 The SPRacingF3 FC doesn't have an onboard OSD chip so you won't be able to use Cleanflight or Betaflight OSD without connecting an external OSD module such as a Minim OSD board, if you can still get them these days that is.
Threads: 7
Likes Received: 40 in 32 posts
Likes Given: 59
3 Swift cam has osd. I think if you hook up that vesn you can check battery too. Hold left stick to the left for a few seconds and see if the camera menu pops up.
For the love of all that is unholy, hook that mic up.
Threads: 7
Likes Given: 59
3 You can also hook the little 5 way that came with the cam to see if that helps nav through the menus.
Threads: 2
Likes Received: 0 in 0 posts
Likes Given: 2
0 Thank y'all so much for the info and help! It really helped learning more about the drone that I just bought!! haha
