Threads: 59
Likes Received: 543 in 318 posts
Likes Given: 730
26 Have you tried to connect to the ESC's through BLHeli ?
Scott
Threads: 12
Likes Received: 0 in 0 posts
0 Oh no not yet..is it worth a short?spent the last hrs looking thru all the wiring and connection. Everything seems ok. Even changed out the wires connecting the fc to esc..still no beeps..esc gone?it is a tekko32 4 in 1
Threads: 125
Likes Given: 99
388 Are you getting stick movements in BFC?
No beeps could just means that your ESC or/and motors are bad. Can you spin your motors in BF?
You have to rule out what components still works and which one doesn't.
Threads: 12
0 26-Aug-2019, 03:45 PM (This post was last modified: 26-Aug-2019, 03:46 PM by Mike.) In betaflight the quad moves when I move the quad, this means the fc is working right?
No all 4motors don't move in betaflight. Battery plugged in.
Threads: 125
Likes Given: 99
388 26-Aug-2019, 03:51 PM (This post was last modified: 26-Aug-2019, 03:51 PM by voodoo614.) Does not rule out FC yet. Just means one part of the FC is working. I meant stick movements from the the receiver. Do you see movem2in receiver tab.
Threads: 59
Likes Given: 730
26 You will not get the beeps unless you have a lipo plugged in. Have you tried it with the lipo ?
Scott
Threads: 12
0 Yes lipo plugged.
Receiver, vtx, taranis all receiving signals.
No beeps and can't arm
Threads: 59
Likes Given: 730
26 See if you can connect to the ESC with BLHeli
Scott
Threads: 125
Likes Given: 99
388 So it can be three things remaining, bad ESC, no signal to the ESC or bad motor. My bet is on bad ESC.
Threads: 12
0 Will try to connect to bheli config after work..I'm guessing bad esc too...
Threads: 125
Likes Given: 99
388 Can you also post what is cli "Status". Make sure you turn on your radio before typing status.
Threads: 59
Likes Given: 730
26 Just to double check, when you connected to BLHeli you did have a battery plugged in right ?
And you did click "read setup" in the lower corner right ?
Scott
