Threads: 43
Likes Received: 286 in 202 posts
Likes Given: 12
5 So, on all my other builds, all two of them hehe, I've used an R-XSR and hooked up S.PORT. The schematic for the F722 shows nothing from the R-XSR's S.PORT. Is there something I need to do instead so the RX works? Pretty sure I've got everything else figured out.
My radio is the Taranis X9D+.
Deal
Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench....
Threads: 125
Likes Given: 99
388 You can use any unused UART TX for S. Port. All F7 FC have switchable inversion.
Threads: 43
Likes Given: 12
5 So, no wire needed? By switchable are you referring to literally switching it on in Betaflight? That sounds like a stupid question, hehe....
Deal
Here's the Deal
Threads: 125
Likes Given: 99
388 Yes, switching in Betaflight.
Use the following CLI command to switch the inversion
set tlm_inverted = ON
Save
Threads: 43
Likes Given: 12
5 Thanks, again, man. I'll give it a try and hopefully by the end of the weekend I'll have her up and running.
Deal
Here's the Deal
