I have a support ticket open with iFlight regarding desync issues with the new XING2 2306 1755kv motors and was wondering if anyone else is experiencing the same?
Have 6 of those motors and all of them are desyncing usually at the bottom of a split s move when trying to spin up the motors from idle to catch yourself. Flips and rolls are usually ok. Motors don't stop working you just have to deal with unpredictable behavior when you are close to the ground. Tried the motors on 2 new builds with different components and issue is present in both. Unable to fix it by changing Blheli32 settings either. Clearly an issue with these new motors.
Hope this helps someone if you are deciding on whether to buy these motors.
Here is betaflight log showing Motor 3 desyncing at 2:12.657 (https://drive.google.com/file/d/11j_HJFs...sp=sharing) mind you this desync happened close to the ground and I slightly tapped the ground but luckily there is no damage to the quad due to this as I was flying over grass. I was kind of expecting a desync so didn't do anything crazy was more of a test flight. Haven't flown the quad since until this gets resolved.
Have bunch of other logs+videos showing each motor desyncing at least once on both quads I had these installed.
