Threads: 81
Likes Received: 14 in 9 posts
Likes Given: 17
1 So I was in the park this morning where I normally go to fly if I do not feel like traveling very far. I bought the new DJI system (Goggles 2, Controller 2, Air Unit 3) and was just flying around and all of the sudden my quad failsafe's and drops to the ground. At first I thought I got too close to the ground and crashed. I went to my quad and inspected it and flew some more. As I was flying I went to the same area and again it failsafed and dropped to the ground. So this time I got a fresh battery and slowly flew from where I sat to the area that I was having a problem with. Sure enough as I was hovering around in a couple different areas it failsafed and dropped to the ground. With this system I upgraded everything from my original DJI v1 stuff, Everything is new. Has anyone heard of localized interference like this??? The attached video show where I lose a signal and get the RX Lost in the goggles (BTW - I love how we can record OSD now).
Threads: 49
Likes Received: 719 in 530 posts
Likes Given: 480
93 Can you show a screenshot of your receiver tab in Betaflight?
Threads: 0
Likes Received: 1 in 1 posts
Likes Given: 0
0 Hi donwie63
The RSSI dbm warning is not useful because DJI RC doesn't support it.
I have the same issue. I fly in a pretty remote area so the only interference is my wireless android auto. For me in only happens when I'm in manual chanal selection. On auto I don't get RX LOSS. And it's always straight ahead of me around 50-100m away. When I fly further away or to the side I don't have the issue.
Also the DJI RC signal bars still show pretty good signal (the same as on your video).
Have you already contacted DJI support?
If not it would be great if you could contact them and send them the logs. So this issue can be fixed.
What setup are you using? Stock DJI antenna or LHCP antennas (on the drone). i have the Iflight Evoque with LHCP antennas.
Threads: 81
Likes Given: 17
1 Update from DJI!!! Soooo... they want me to remove my Air Unit from my quad and send it in to them so that they can disect it to see if there is anything wrong with it. I told them that if they send me a new one first, then I would swap it out and send them the original one for their inspection. I do not think they will agree. I think I will fly in Auto mode till the next firmware update to see if they addressed this issue.
