17-Feb-2020, 02:28 AM
I have a tinyhawk freestyle with a F4 FC and I am wanting to replace the receiver with an R9MM, since I am low on funds and I plan on keeping this one for a while, so I want to be able to take it out for a spin. SO, on the R9MM receiver, it has pads for SBUS OUT, S.PORT/F.PORT, GND, V-IN (POS), and Inverted S-Port. SO on the bottom of the flight controller, there are pads with RX1 and TX1 and TX2 and on the top of the FC, where the RX1 pad is, is the camera plug for the camera pigtail. So is the TX1 and TX2 where I should get the S.Port and then invert serial_rx in the CLI, or keep it the way it is? Or should I use SBUS for S.Port or is SBUS where the SBUS-OUT goes? I'm new to this so any expert advice would be greatly appreciated. Also, I know that SBUS can be inverted because I have the option to do so in the CLI and I seen a guy on YouTube upgrade his Tinyhawk Freestyle with new XM+ receiver and he did an inverted serial RX in the CLI. Please help. Thanks in advance.
