23-Jun-2018, 05:12 PM
The drawing below shows FRSky telemetry sharing the UART 1 USB port. Does this work? I assume you cannot have both active at the same time. It does make sense because you don't need telemetry when you are connected to your computer and you are not connected to a computer when you are flying. How do you switch between USB function and telemetry (SmartPort). If I configured UART 1 for smartport and rebooted I assume I could not communicate to that port w/o a complete bootloaded reboot. Also if this does work I guess I need the non-inverted output on my FYSky R-XSR. I have this working connected to softserial but I want to enable the LED function at the same time. You can't have softserial and LED enabled at the same time.
