Threads: 1
Likes Received: 1 in 1 posts
Likes Given: 3
0 Hi all! I have been working on this NanoLongRange build for a while and I finally got back to working on it. I have it setup essentially exactly as DaveC did but I have used a Happymodel ELRS SX1280 RX instead of a Crossfire or Frsky. I have the Happymodel ES24TX in my QX7s. Both TX and RX have been updated and auto bind on powerup. I believe I have betaflight configured correctly but if I try to arm or move the sticks, nothing changes on the receiver tab. I cant seem to figure out why it doesnt work when everything appears to be setup correctly. Any tips or info on what the issue might be is greatly appreciated. I can supply more info or pictures if required.
Thanks in advance.
Threads: 38
Likes Given: 430
118 A CLI dump and a photo of the wiring will help.
I assume you have already turn on Serial_RX on the UART you connected the ELRS RX and also selected Serial based receiver and CRSF as the Receiver protocol.
Threads: 49
Likes Received: 713 in 524 posts
Likes Given: 477
93 The TX pad on the receiver should be connected to the R2 pad on the flight controller. You have a wire going to the pad next to it.
Threads: 49
Likes Given: 477
93 The receiver is meant to solder to the through holes in the row with the 5V and ground pads, then you bridge between the RC and SBUS or R2 pads depending on whether your receiver uses SBUS. You want R2.
So, you can either solder to the RC pad between T2 and 5V and bridge the pads between RC and R2, or just solder to R2 directly.
Threads: 49
Likes Given: 477
93 It actually flies better without the prop screws due to less rotating weight. The other critical parts of the build are to make sure you use a capacitor on the FC, and performance is much better if you skip the 18650 cell holder and solder an XT30 to the cell directly.
Threads: 1
Likes Given: 3
0 I have a capacitor on the FC. The props I bought apparently have too large of a center bore so I cant do push on only. I just ordered some that should just push on. I have all the props on and everything seems to work but it doesn't want to take off it seems. all motors are turning correctly according to what betaflight says and I *think* I have the props on the correct motors. Not sure why else it wouldn't want to take off.
Threads: 49
Likes Given: 477
93 Does the model move correctly in the Betaflight setup screen if you tilt it forward, back, left, and right?
Take a picture of the props on the quad and we can verify they are on properly.
Threads: 1
Likes Given: 3
0 Unfortunately I left for work before I saw your reply. From memory I believe it moved correctly in betaflight when tilted all directions. I will take a picture of the mounted rotors when I get home from work. Thanks again for all your help. It is appreciated very much.
Threads: 1
Likes Given: 3
0 After some googling I found BlHelisuite. I was able to change the direction of the motor and I am finally able to get it off the ground! now I just need to learn to fly lol. Thanks for all the help!
Threads: 118
Likes Received: 1,411 in 728 posts
Likes Given: 1,069
41 You’ve done well to navigate the problems with help from some great members of this forum!
