motors do not spin from reciever. PLZ HELP I NEED TO GET THIS TO WORK THIS WEEK
Exclamation
I have a bnf cinelog 35 v2 analog gps elrs and a tx12 mkii elrs. I have been trying to get the drone to fly for the longest time and have been unable to get it working. On betaflight I can see the tranciever inputs and I calibrated it so all my sticks are between 1000 and 2000. Additionally the motors run when I use betaflight but do not work at all when trying to use the receiver. I attached the dump and diff all cmd as well if needed.
.txt   # dump.txt (Size: 30.06 KB / Downloads: 12)
I do not see any attachments...
here it is below idk y it didnt show before
# dump
# Betaflight / STM32F7X2 (S7X2) 4.4.2 Dec 12 2023 / 19:07:57 (23d066d08) MSP API: 1.45
# config: YES
# start the command batch
batch start
board_name GEPRC_F722_AIO
manufacturer_id GEPR
# name: Cinelog35 V2
# resources
resource BEEPER 1 C15
resource MOTOR 1 C09
resource MOTOR 2 C08
resource MOTOR 3 C07
resource MOTOR 4 C06
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource LED_STRIP 1 A01
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 C10
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 C11
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 B10
resource I2C_SCL 3 NONE
resource I2C_SCL 4 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 B11
resource I2C_SDA 3 NONE
resource I2C_SDA 4 NONE
resource LED 1 C04
resource LED 2 NONE
resource LED 3 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_SCK 4 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MISO 4 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource SPI_MOSI 4 NONE
resource ADC_BATT 1 C02
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 B09
resource OSD_CS 1 B12
resource GYRO_EXTI 1 A08
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A15
resource GYRO_CS 2 NONE
resource USB_DETECT 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer A00 AF2
# pin A00: TIM5 CH1 (AF2)
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer C06 AF3
# pin C06: TIM8 CH1 (AF3)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer C07 AF3
# pin C07: TIM8 CH2 (AF3)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer A01 AF1
# pin A01: TIM2 CH2 (AF1)
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MOSI 4 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_MISO 4 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_TX 4 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma SPI_RX 4 NONE
dma ADC 1 NONE
dma ADC 2 NONE
dma ADC 3 0
# ADC 3: DMA2 Stream 0 Channel 2
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A00 0
dma pin A03 NONE
dma pin C08 1
# pin C08: DMA2 Stream 4 Channel 7
dma pin C06 0
# pin C06: DMA2 Stream 2 Channel 0
dma pin C09 0
dma pin C07 1
# pin C07: DMA2 Stream 3 Channel 7
dma pin B06 0
dma pin B07 0
dma pin B01 0
dma pin B00 0
dma pin A01 0
# pin A01: DMA1 Stream 6 Channel 3
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature RX_SERIAL
feature GPS
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
serial 0 8192 115200 57600 0 115200
serial 3 64 115200 57600 0 115200
serial 4 2 115200 115200 0 115200
# mixer
mixer QUADX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1500 2100 0 0
aux 1 1 2 900 1300 0 0
aux 2 46 5 1700 2100 0 0
aux 3 13 1 1700 2100 0 0
aux 4 35 3 1700 2100 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 6
vtxtable channels 8
vtxtable band 1 BOSCAM_A A CUSTOM  5865 5845 5825 5805 5785 5765 5745 5725
vtxtable band 2 BOSCAM_B B CUSTOM  5733 5752 5771 5790 5809 5828 5847 5866
vtxtable band 3 BOSCAM_E E CUSTOM  5705 5685 5665 5665 5885 5905 5905 5905
vtxtable band 4 FATSHARK F CUSTOM  5740 5760 5780 5800 5820 5840 5860 5880
vtxtable band 5 RACEBAND R CUSTOM  5658 5695 5732 5769 5806 5843 5880 5917
vtxtable band 6 LOWRACE  L CUSTOM  5362 5399 5436 5473 5510 5547 5584 5621
vtxtable powerlevels 4
vtxtable powervalues 25 200 500 1000
vtxtable powerlabels 25 200 500 MAX
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 0 s 1500
rxfail 1 s 1500
rxfail 2 s 1500
rxfail 3 s 1250
rxfail 4 h
rxfail 5 h
rxfail 6 s 1000
rxfail 8 h
rxfail 9 h
# master
set gyro_lpf1_type = PT1
set gyro_lpf1_static_hz = 250
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 500
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_calib_noise_limit = 120
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 1
set dyn_notch_q = 500
set dyn_notch_min_hz = 100
set dyn_notch_max_hz = 600
set gyro_lpf1_dyn_expo = 5
set acc_hardware = AUTO
set acc_lpf_hz = 25
set acc_trim_roll = 0
set acc_calibration = -5,-9,-25,1
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 2
set baro_i2c_address = 0
set baro_hardware = AUTO
set min_check = 1005
set max_check = 1995
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rssi_smoothing = 125
set rc_smoothing = ON
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set sbus_baud_fast = OFF
set serialrx_halfduplex = OFF
set adc_device = 3
set blackbox_disable_rc = OFF
set blackbox_mode = NORMAL
set blackbox_high_resolution = OFF
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 550
set dshot_burst = ON
set dshot_bidir = ON
set dshot_edt = OFF
set dshot_bitbang = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set motor_output_reordering = 2,3,0,1,4,5,6,7
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 6
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = GPS-RESCUE
set align_board_yaw = 0
set bat_capacity = 0
set vbat_max_cell_voltage = 420
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 100
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set beeper_dshot_beacon_tone = 3
set yaw_motors_reversed = ON
set mixer_type = LEGACY
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set small_angle = 180
set imu_process_denom = 2
set gps_provider = UBLOX
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_ublox_mode = AIRBORNE
set gps_set_home_point_once = ON
set gps_use_3d_speed = OFF
set gps_sbas_integrity = OFF
set gps_rescue_min_start_dist = 30
set gps_rescue_initial_climb = 10
set gps_rescue_ascend_rate = 750
set gps_rescue_return_alt = 30
set gps_rescue_ground_speed = 750
set gps_rescue_max_angle = 70
set gps_rescue_roll_mix = 150
set gps_rescue_pitch_cutoff = 75
set gps_rescue_descent_dist = 50
set gps_rescue_descend_rate = 120
set gps_rescue_landing_alt = 4
set gps_rescue_disarm_threshold = 25
set gps_rescue_throttle_max = 1700
set gps_rescue_throttle_hover = 1275
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY
set gps_rescue_min_sats = 5
set gps_rescue_throttle_p = 15
set gps_rescue_throttle_i = 15
set gps_rescue_throttle_d = 20
set gps_rescue_velocity_p = 8
set gps_rescue_velocity_i = 40
set gps_rescue_velocity_d = 12
set gps_rescue_yaw_p = 20
set deadband = 1
set yaw_deadband = 1
set pid_process_denom = 4
set tlm_inverted = OFF
set tlm_halfduplex = ON
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set ledstrip_brightness = 100
set osd_units = METRIC
set osd_warn_bitmask = 8191
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = -60
set osd_rsnr_alarm = 4
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = 0
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 2113
set osd_rssi_pos = 234
set osd_link_quality_pos = 2177
set osd_rssi_dbm_pos = 234
set osd_rsnr_pos = 234
set osd_tim_1_pos = 234
set osd_tim_2_pos = 2135
set osd_flymode_pos = 2156
set osd_g_force_pos = 234
set osd_throttle_pos = 2188
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_wh_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 2121
set osd_pilot_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 2081
set osd_gps_lat_pos = 2097
set osd_gps_sats_pos = 2230
set osd_home_dir_pos = 2285
set osd_home_dist_pos = 2200
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 2166
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 14665
set osd_avg_cell_voltage_pos = 2145
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_ready_mode_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_aux_pos = 234
set osd_sys_goggle_voltage_pos = 234
set osd_sys_vtx_voltage_pos = 234
set osd_sys_bitrate_pos = 234
set osd_sys_delay_pos = 234
set osd_sys_distance_pos = 234
set osd_sys_lq_pos = 234
set osd_sys_goggle_dvr_pos = 234
set osd_sys_vtx_dvr_pos = 234
set osd_sys_warnings_pos = 234
set osd_sys_vtx_temp_pos = 234
set osd_sys_fan_speed_pos = 234
set osd_stat_bitmask = 14124
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_gps_sats_show_hdop = ON
set osd_framerate_hz = 12
set osd_aux_channel = 1
set osd_aux_scale = 200
set osd_aux_symbol = 65
set osd_canvas_width = 30
set osd_canvas_height = 13
set osd_craftname_msgs = OFF
set task_statistics = ON
set debug_mode = GYRO_SCALED
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 5
set vtx_channel = 1
set vtx_power = 3
set vtx_softserial_alt = OFF
set vtx_freq = 5658
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = NOMINAL
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set displayport_msp_fonts = 0,0,0,0
set led_inversion = 0
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW90FLIP
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 1800
set gyro_1_align_yaw = 900
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set scheduler_relax_rx = 25
set scheduler_relax_osd = 25
set serialmsp_halfduplex = OFF
set rpm_filter_harmonics = 3
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_lpf_hz = 150
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set craft_name = Cinelog35 V2
set pilot_name = -
set altitude_source = DEFAULT
set altitude_prefer_baro = 100
set altitude_lpf = 300
set altitude_d_lpf = 100
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
# profile 0
set profile_name = 6S
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_type = PT1
set dterm_lpf1_static_hz = 75
set dterm_lpf2_type = PT1
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation = 0
set pid_at_min_throttle = ON
set anti_gravity_gain = 80
set anti_gravity_cutoff_hz = 5
set anti_gravity_p_gain = 100
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 15
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 100
set throttle_boost = 5
set p_pitch = 49
set i_pitch = 79
set d_pitch = 42
set f_pitch = 104
set p_roll = 47
set i_roll = 75
set d_roll = 36
set f_roll = 100
set p_yaw = 47
set i_yaw = 75
set d_yaw = 0
set f_yaw = 100
set angle_level_strength = 80
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 28
set d_min_pitch = 32
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 0
set feedforward_smooth_factor = 65
set feedforward_boost = 15
set dyn_idle_min_rpm = 0
set dyn_idle_p_gain = 50
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set level_race_mode = OFF
set simplified_master_multiplier = 105
set simplified_i_gain = 90
set simplified_d_gain = 90
set simplified_pi_gain = 100
set simplified_dmax_gain = 90
set simplified_feedforward_gain = 80
set tpa_mode = D
set tpa_rate = 65
set tpa_breakpoint = 1350
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set roll_rc_rate = 7
set pitch_rc_rate = 7
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set pitch_srate = 67
set yaw_srate = 67
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
# end the command batch
batch end
# diff all
# config: YES
batch start
defaults nosave
mcu_id 002e00373432500820393650
signature
feature GPS
# beacon
beacon RX_LOST
beacon RX_SET
# vtxtable
vtxtable bands 6
vtxtable channels 8
# rxfail
rxfail 0 s 1500
rxfail 1 s 1500
rxfail 2 s 1500
rxfail 3 s 1250
rxfail 6 s 1000
# master
set deadband = 1
set vtx_band = 5
set vtx_channel = 1
set vtx_power = 3
set vtx_freq = 5658
# profile 0
set p_pitch = 49
set i_pitch = 79
set d_pitch = 42
set f_pitch = 104
set p_roll = 47
set i_roll = 75
set d_roll = 36
set f_roll = 100
set p_yaw = 47
set i_yaw = 75
set f_yaw = 100
set d_min_roll = 28
profile 1
# profile 1
set profile_name = 6S+GoPro
set p_pitch = 49
set i_pitch = 92
set d_pitch = 32
set f_pitch = 131
set p_roll = 47
set i_roll = 88
set d_roll = 31
set f_roll = 125
set p_yaw = 47
set i_yaw = 88
set f_yaw = 125
set d_min_roll = 31
set simplified_i_gain = 105
set simplified_dmax_gain = 0
set simplified_pitch_d_gain = 90
profile 2
profile 3
rateprofile 1
rateprofile 2
rateprofile 3
# save configuration
sav
If you are seeing the bars move in the Betaflight Configurator receiver tab then it proves that the ExpressLRS receiver is communicating with the FC.
When you flip the ARM switch on your transmitter, do you see the AUX 1 channel bar moving? If not then it means that you haven't configured an ARM mode switch on your RadioMaster TX12 transmitter so you will need to do that. If you are seeing the AUX 1 bar moving when you flip your ARM switch then there is likely another condition present that is preventing the motors from arming. Make sure your throttle is all the way down whenever you try to arm the the motors. If doing that is still unsuccessful then please run the "status" command in the Betaflight Configurator CLI tab with the ARM switch in the disarmed position, and run the same command again with the ARM switch in the armed position, then post the output results from both of those back here.
(21-Mar-2024, 10:01 AM)SnowLeopardFPV Wrote: If you are seeing the bars move in the Betaflight Configurator receiver tab then it proves that the ExpressLRS receiver is communicating with the FC.
ARM OFF
MCU F722 Clock=216MHz, Vref=3.29V, Core temp=41degC
Stack size: 2048, Stack address: 0x20010000
Configuration: CONFIGURED, size: 3644, max available: 16384
Devices detected: SPI:1, I2C:0
Gyros detected: gyro 1 locked dma
GYRO=ICM42688P, ACC=ICM42688P
OSD: MAX7456 (30 x 13)
BUILD KEY: ab9803c632c88c45a71f544d03c9a4d9 (4.4.2)
System Uptime: 107 seconds, Current Time: 2024-03-21T14:17:26.428+00:00
CPU:26%, cycle time: 124, GYRO rate: 8064, RX rate: 1003, System rate: 9
Voltage: 372 * 0.01V (1S battery - OK)
I2C Errors: 1
FLASH: JEDEC ID=0x00ef4018 16M
Arming disable flags: CLI MSP GPS
ARM ON
# status
MCU F722 Clock=216MHz, Vref=3.29V, Core temp=43degC
System Uptime: 159 seconds, Current Time: 2024-03-21T14:18:18.524+00:00
CPU:26%, cycle time: 123, GYRO rate: 8130, RX rate: 1002, System rate: 9
Voltage: 369 * 0.01V (1S battery - OK)
I2C Errors: 1
Arming disable flags: CLI MSP GPS ARMSWITCH
Your flag is showing GPS. Maybe because you have min sats set to 5, so your quad will not arm until you have acquired GPS lock with 5 sats. If your OSD is working, you should also see the arming errors/message in your video feed.
[-] The following 1 user Likes mstc's post:
  • Rob Axel
(21-Mar-2024, 03:47 PM)mstc Wrote: Your flag is showing GPS. Maybe because you have min sats set to 5, so your quad will not arm until you have acquired GPS lock with 5 sats. If your OSD is working, you should also see the arming errors/message in your video feed.
i turned arm withouht fix to bypass that issue but the drone still does not want to turn when arming from the transciever and then applying throttle.
You have mapped your arm switch to AUX1 and setup the ARM in the BF modes tab? When you are in the modes tab and flip the arm switch, do you see the MODE highlighted?
What message are you getting on your OSD? Or share your new status.
[attachment=11997 Wrote: mstc pid='215779' dateline='1711050226']You have mapped your arm switch to AUX1 and setup the ARM in the BF modes tab? When you are in the modes tab and flip the arm switch, do you see the MODE highlighted?
i added the screenshot with the arm enabled from the transciever. as well as what I see on the osd
Attached Files Thumbnail(s)
I believe MSP indicates you still have your FC connected to BF configuration. You must disconnect the usb cable before arming, it will not arm while you are connected.
MSP.. that means the fc is connected to betaflight if I remember…
Disconnect it, make sure your switches are correct and throttle is down, try arming and then see what the osd shows you
(21-Mar-2024, 09:11 PM)mstc Wrote: I believe MSP indicates you still have your FC connected to BF configuration. You must disconnect the usb cable before arming, it will not arm while you are connected.
okay so i just got it to work miraculously with the receiver, but it was spinning when the throttle was all the way at the bottom, and then it kinda just freaked out
Spinning up props at arm is normal, if you have it in angle mode, it will try to self level. If you arm in acro mode and drone is flat/stable the motors should spin very softly.
If it is "freaking out" as in flipping over or yawing with no stick movements, then you may have motors mapped wrong, or motor direction, or props/prop direction not setup correctly. Is that a stock BNF cinelog? If it is then the BF settings should be correct out of the box, but check your prop direction/orientation.
(21-Mar-2024, 09:58 PM)mstc Wrote: Spinning up props at arm is normal, if you have it in angle mode, it will try to self level. If you arm in acro mode and drone is flat/stable the motors should spin very softly.
oh okay then its normal, the drone spins slowly when I arm, but when applying light throttle it starts to creep forward, what would cause that issue, or is that normal behavior this is my first drone btw
#15
If you are testing the motors with props off on the bench then that behaviour is completely normal and is to do with the PID controller detecting no expected change in attitude of the quad as the motor RPM is raised, so it keeps raising the motor RPM higher and higher to try and get the quad to lift off the ground because it thinks there isn't yet enough thrust to do so which is why your motors can appear to behave erratically or spin up to max RPM by themselves. Have a watch of the following video to understand why. To get proper behaviour you need to put the props on and take it outside for a hover test. You will then find that the motors behave as commanded by your transmitter.
  Why do higher voltage batteries need lower KV motors? Eyes.fpv 1 97 04-May-2024, 01:42 AM
Last Post: SeismicCWave
  Motors not responding to transmitter input(no airmode) corwin 1 80 22-Apr-2024, 05:07 PM
Last Post: mstc
  Beta95x V3 motors not start kronk 3 122 20-Apr-2024, 07:28 PM
Last Post: kronk
  BFC REORDER MOTORS NOT SPINNING soky157 4 107 08-Apr-2024, 05:38 AM
  Issues Installing ELRS Reciever NyxOTNC 14 1,652 04-Apr-2024, 08:07 PM
Last Post: tr8d3r8
