motor problem!! |
06-Apr-2019, 09:46 AM You may have bent the shaft or damaged the magnets / stator / windings. Not always easy to tell without taking it apart. It could also be an issue with the solder joints where the 3 wires attach to the windings. You would need to cut off the heatshrink to check. One other thing. To ensure the problem definitely is the motor and not an ESC, swap the motor over with another one and see if the problem remains with the suspect motor. 08-Apr-2019, 04:34 PM Can you spin the motor freely as the other motors when it's powered of and lipo disconnected? |
Problem no rx led in meteor 75 pro frsky version | arju | 11 | 232 | 09-Jun-2024, 06:27 PM Last Post: arju | |
drone problem | Filip371 | 1 | 140 | 08-Jun-2024, 08:35 PM Last Post: hugnosed_bat | |
Motor/esc problem | Axel | 42 | 1,254 | 26-May-2024, 10:15 AM Last Post: wizofwires | |
Problem With compatibility | Adicjusz | 6 | 278 | 22-May-2024, 11:40 PM Last Post: SeismicCWave | |
Motor under water | Eyes.fpv | 5 | 225 | 04-May-2024, 05:16 PM Last Post: SnowLeopardFPV |
