29-Jan-2021, 06:42 AM (This post was last modified: 29-Jan-2021, 08:04 AM by rockford007.)
Hi,
Just started making a whoop with brand new JHEMCU 411 Pro AIO controller and 4 rcinpower motors. After hooking everything together all bound properly and was receiving signal, but started to notice two motors (1 and 2) are jittering, not spinning properly. If I slide in motor tab then 'sometimes' all spin fine and 'sometime' it jitters but after arming they never spin fine. I tried replacing motors but motors are fine as they spins good in other side. So is my AIO esc fried or some parameter needs to be changed.
Tried flashing firmware, tried updating jesc firmware and other things... not sure if new AIO is already damaged I didn't even get chance to fly once
Also I should mention few times saw slight smoke coming out from the area of esc...
Here is a video what is happening..
https://drive.google.com/file/d/1slQEMvE...sp=sharing
