26-Jan-2020, 04:09 PM (This post was last modified: 26-Jan-2020, 04:27 PM by Smokie.)
more setting questions
1)The OSD settings display on the FPV screen works oke (bat volt,home dir enz enz)
however ; to activate OSD menu , do this stick combination: mid throttle,yaw left,pitch forward , dos not work it did before cant find what to change(what if changed)
2) vtx settings in dump; set vtx_band = 4 set vtx_channel = 1 set vtx_power = 1 set vtx_low_power_disarm = ON set vtx_freq = 5740 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON
When trying to enter the CMS menu, you want to make sure that your endpoints and midpoints are correct.
I am not quite sure why your frequency is off. Can you manually change the channel and see if you have the same problem with another channel? See if the VTX CLI changes. A lot of times, if you don't have Smartaudio setup, then the Betaflight VTX settings is ignored.
Are you using Betaflight 4.0 or greater and have you setup your VTx table in the VTx tab of Betaflight? If not which VTx are you using and do you happen to know which SmartAudio version it uses?
26-Jan-2020, 08:48 PM (This post was last modified: 26-Jan-2020, 10:57 PM by Smokie.)
(26-Jan-2020, 08:15 PM)voodoo614 Wrote: When trying to enter the CMS menu, you want to make sure that your endpoints and midpoints are correct.
Yes ,the midpoint settings is what i can adjust Begin and end point setting is not what i am doing right Will look in to that again
Manualy change of the vtx have the same problem it jumps from c-8 to d-3 and skips d-1 My first stack was whitout that problem and went to d-1 5740 oke As far as i know i have smart audio set up?
I have been busy with runcam settings and osd settings and pal/ntsc changing Before i was getting osd menu oke and could change them with stick control tr mid yaw left pitch up
Tomorrow a new search day! New quad flys perfekt!!
Are you using Betaflight 4.0 or greater no 3.4 and have you setup your VTx table in the VTx tab of Betaflight? No If not which VTx are you using Hglrc forward vtx mini and do you happen to know which SmartAudio version it uses? No idee Wr Henk
26-Jan-2020, 09:15 PM (This post was last modified: 26-Jan-2020, 09:15 PM by SnowLeopardFPV.)
(26-Jan-2020, 09:03 PM)ProppedCodger Wrote: Well then it sounds like you need to determine which SA version (Tramp, SA2, SA2.1?) your VTx is on and then configure it in the Betaflight tab. Which VTx are you using there?
VTX tables aren't needed for Betaflight 3.4.0 which is the version of BF that Smokie is currently running. So it should just work as-is without any configuration, as per the "old days".
He is using 3.4, per the dump file. So VTX table has not been implemented.
Edit: I guessed Snow already explained it. Sorry for commenting again.
