Threads: 8
Likes Received: 29 in 14 posts
Likes Given: 8
3 I would like to migrate my Chimera 7 Pro from the factory flashed and tuned BF version 4.2.11 to the latest stable BF release (BF 4.3.1 if I'm correct). This isn't rocket science for most of the settings and rates but I'm not so sure on how to approach transfering the factory tune to the new BF version.
Does anybody know how to succesfully migrate a tune to a new BF version?
Threads: 172
Likes Received: 2,293 in 1,840 posts
Likes Given: 4,743
103 you cant migrate a tune to another bf version, you need to tune it freshly.
maybe its better to stay on your tuned version, maybe there are tunes outthere for 4,3 as it is a popular pnp
Threads: 8
Likes Given: 8
3 20-Dec-2022, 07:30 PM (This post was last modified: 20-Dec-2022, 07:41 PM by martijnv.) Fixed it! Today JB posted a review of the Chimera 7 pro V2 on his YouTube channel and mentioned a iFlight factory settings repo to be used in the presets tab of BF Configurator.
This took away my worries when pondering migrating to BF 4.3.x, I'm still unable to check if the ESC is configured for 48 kHz (for long range) as the esc-configurator website says there is an error about an incorrect number of esc channels detected. I'm on macOS and run esc-configurator in chrome, same problem persists on a Windows laptop with edge.
<edit>
ESC configuration mismatch solved, I didn't know there was a BLHeli suite available for macOS, esc's are configured for 48 Khz. Time to finalize the configuration and fly this magnificent beast later this week to iron out migration issues.
</edit.
Threads: 8
Likes Given: 8
3 Did a 17 minute test flight yesterday including a gps rescue test and all went exceptionally well. I need to replace the elrs rx for a ep1 dual rx because I had a few RF warnings which where a result of the single antenna mounting orientation.
