Micro MinimOSD VideoIN shorts to GROUND?
I've found a bit of an odd problem. My Micro MinimOSDs (All three of them) have VideoIN shorting to ground, that makes me a bit reluctant to plug mine in, but I'm not sure if it's normal or not? It's present on 3 separate boards from 2 suppliers.
I can't find any documentation about this anywhere else. Can someone please explain what's going on here?
I think it's normal, someone knows the MAX chip better might be able to explain why... but it's not really a short and there is some resistance between Video in and GND...
I checked mine and vout or vin are not shorted to ground. On the other hand, them being shorted to GND will at most give you no image, but shouldn't damage anything.
try to actually measure the value of the resistance, rather than just checking for shorts... have you actually tried it with a camera and VTX yet?
(06-Apr-2016, 11:42 PM)CurryCat Wrote: I think it's normal, someone knows the MAX chip better might be able to explain why... but it's not really a short and there is some resistance between Video in and GND...
 No, not yet. I'm in the process of installing it now. I was worried that I'd screwed the soldering up with the one I did myself. It was only after I got the next two units that I figured it was actually supposed to be like that, but I'd still really like to know why ...
I once had the same concerns. But it is totally fine, the resistance is like 54 or 74 ohms if I remember it correctly.
My quad:
RD-210 / ZMX V3 2206 2140kv / Aikon SEFM 30A / X-Racer F303 V3 / X4R-SB / Dronelab 1500 4S 50C
Question Help Betaflight OSD is not working (F405v3, TX800, Foxeer T-Rex Micro) maggrave 5 1,336 20-Oct-2023, 11:17 PM
  High Antenna worse than at ground Level?? Evaredy 5 410 01-May-2023, 12:29 AM
Last Post: Evaredy
  Help FCF411-FTE & Video TX Atlatl HV micro problems ashewan 0 252 15-Jan-2023, 02:34 PM
Last Post: ashewan
  Help MinimOSD with Pixhawk 2.4.8 EZDRONE 0 296 12-Jan-2022, 05:06 PM
Last Post: EZDRONE
  Review Furious FPV Dock King Lite (Compact Ground Station) the.ronin 8 3,257 17-Oct-2021, 02:42 AM
Last Post: Rick h
