29-Jan-2024, 01:30 PM
This is a long term work in progress.
I've always wanted a home/backyard flyer in the 3inch variety that was like the betafpv hx11lr frame, but better. HX115 LR Toothpick Drone – BETAFPV Hobby
This one was unique in the sense of a 1S bus style chassis design for the frame. Given a lot of 1S stuff is toothpick this was a bit different. It suffered from issues of course, namely those crappy frame screws that weren't standard. It was also tricky to fit anything digital (especially early walksnail nano cams) into it. Like the Armattan Odonata (also bus style frame but smaller prop size) this frame had analog in mind when designed.
What I'm interested in is a frame of similar style but really low profile with the battery mounted on top. I've done a lot of toothpick stuff and feel that the traditional battery at the bottom mount design hinders performance, especially coming out of a dive, this is like the textbook of challenges on (digital) 1S.
So I thought, instead of stacking the aio and vtx, put them side by side and go for a really low mount. In the end I achieved on a 3d printed prototype at 8mm internal clearance. Measured from lower deck to top deck. Just enough to fit a 1/2S AIO and a walksnail/hdzero aio shaped vtx.
I am using the NanoLongrange project STL files as the basis of the draft model. I hacked together a shitty model in tinkercad. Eventually I want this in CF for the top and bottom frame plates. Then TPU print for camera mount and TPU print for rear antenna array / GPS.
The design has the digital vtx up front and the aio fc at the rear. Either way, you will need a long vtx antenna or a long mipi camera cable if you choose to swap this orientation around. Bit of a pain and a limitation. The goal is to get the battery on top but low and close to the thrust line. I'm hoping the fickle nature of 1S flight will appreciate this design element and return the favour with improved performance, especially in the handling dept.
The motor wires also need to take bit of a long walk, under the digital vtx and to the rear aio. Everything to do with wires in this build is increased. With the 8mm clearance I can get them under the vtx and over the fc without putting pressure on anything, too much.
Components on this build.
This 3d print version took on a life of its own. I designed the top deck to snap into the camera housing to help hold it down. There are no standoffs. The two AIOs have eight plastic screws holding them in. The camera and motors are all mounted with plastic screws. This keeps the weight to 59g dry which (for a 3d print) I'm happy with. Regular 2mm silicon whoop gummies are used with an extra silicon rubber placed on top. This fits the 8mm clearance profile well. The vtx usb port and the fc usb port don't touch the top plate with the 8mm clearance.
The vtx antenna is not in the final position, this will change. I've mounted it on the arm for now to get it in the air.
The battery pad is made out of TPU and glued on. It's not the best but better than the hard surface of the PLA. I've also done this for screw head clearance. Again, not final, it raises the battery profile for one thing and I question needing the extra screws under the battery footprint all together.
Here's the end goal, battery position check.
Without the TPU battery pad the props are dead middle of the battery. I'm keen to see what this does.
A quick test this evening and it does fly. Will need to tune and maiden properly tomorrow morning.
Ultimately this is a test for something that will eventually be CF. So I'm drawing inspiration from the NBD savage bee frame as well: NewBeeDrone SavageBee V1.8 Frame 65mm/3inch - Buzz Fpv I like the lattice like design. Having built a toothpick with it have found it rather strong and very light.
Will post video tomorrow if I don't break it!
- HM 1202.5 11500kV motors
- WS 1S vtx(v2), nano camera, ultra short mipi cable(lite kit)
- Betafpv 12A 1S digital only AIO (V3 with Aterytek MCU)
