Losing Control - Blackbox Log
It's my second day flying this year, and I have a mystery.  After not having any issues yesterday, I've been experiencing something odd.  I lose control and drop out of the sky.  I'm not exactly sure why.  I'll be flying around fine, then it loses control, and down she goes.  If you have any ideas, let me know.  Smile
The blackbox log attached is the only one I was able to capture today, but it happened several times.
I'm running a Dodo FCB, Atas PDB, MRM Zeus ESC, Cobra Motors
Blackbox Log
# BetaFlight/SPRACINGF3 2.6.1 Apr  8 2016 / 22:45:22 (bdaf8ec)
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature -TRANSPONDER
feature VBAT
feature RX_SERIAL
feature MOTOR_STOP
feature FAILSAFE
feature TELEMETRY
feature ONESHOT125
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map TAER1234
serial 1 32 115200 57600 0 115200
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
aux 0 0 0 1300 2100
aux 1 27 0 1700 2100
aux 2 12 1 1300 2100
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 4 900 1250 6 3
adjrange 1 0 4 1300 1700 7 3
adjrange 2 0 4 1750 2100 8 3
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set min_check = 1100
set max_check = 1900
set rssi_channel = 16
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1035
set max_throttle = 2000
set servo_center_pulse = 1500
set use_oneshot42 = OFF
set use_multishot = OFF
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 111
set vbat_min_cell_voltage = 35
set vbat_warning_cell_voltage = 36
set vbat_hysteresis = 1
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 90
set gyro_lpf = OFF
set gyro_sync_denom = 8
set gyro_lowpass_hz =  80.000
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 3
set yaw_deadband = 3
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set super_expo_factor = 30
set failsafe_delay = 10
set failsafe_off_delay = 50
set failsafe_throttle = 1200
set failsafe_procedure = ON
set gimbal_mode = NORMAL
set acc_hardware = AUTO
set acc_lpf_hz =  10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set baro_hardware = AUTO
set mag_hardware = AUTO
set mag_declination = 0
set pid_process_denom = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# profile
############################# PROFILE VALUES ####################################
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 400
set dterm_lowpass_hz =  70.000
set dterm_average_count = 4
set iterm_reset_degrees = 200
set yaw_iterm_reset_degrees = 50
set yaw_lowpass_hz =  70.000
set p_pitch = 92
set i_pitch = 14
set d_pitch = 28
set p_roll = 80
set i_roll = 14
set d_roll = 23
set p_yaw = 100
set i_yaw = 50
set d_yaw = 5
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 55
set i_level = 55
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
# rateprofile
set rc_rate = 100
set rc_expo = 65
set rc_yaw_expo = 20
set thr_mid = 30
set thr_expo = 10
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 70
set tpa_rate = 10
set tpa_breakpoint = 1500
you can check RXSignalReceive and Failsafe Phases in blackbox, for example if it's a RX issue,
[Image: pnGjqKll.png]
but in your case, it doesn't look like it's the radio, failsafe wasn't triggered at that time
could that be a FC reboot? somehow it lost power after those roll and flips? check the cable that powers the FC isn't loose
I do have audio from the quad, and I did hear ESC beeps at least once when it was happening. The wiring is solid, no loose connections. I double checked my double check. Wink
I'll have to try a different FCB. If that doesn't fix it, I'll replace ESCs.
Thanks for taking a look Oscar!
I would double triple check you power to fc like Oscar said. If you are getting reinitialization ESC beeps its either the fc power or main lipo power to pdb. I recently had a bad connection to my pololu and could get the esc's to beep when pushing on it. A little solder or a pololu is cheaper than 4 esc's Smile Good luck!
It could be a bad wire. I'll replace that first. The soldering is good. I'll give it a test tonight.
Thanks again! Smile
If you are running XT60 connectors, just check that the Lipo one is a nice snug fit into the one on the quad, the Male pins inside the XT60 connector on the quad will eventually close and makes the connection a bit loose. A small phillips head jewelers screwdriver fits perfectly inside the pin and enables you to widen them just slightly to regain that snug fit.
This happened to me once and I tried everything, esc's, Fc, PDB and finally tracked down the culprit. it only has to lose connection for a split second and you will crash.
My youtube channel
Thanks for the reply BigglesFPV!  I checked the XT60, and it's tight.  I never drop video when it happens, not even a glitch.  I see and hear it all.
I replaced the power wires to the FC this morning.  I'm not optimistic that's going to fix it.  I powered it up, and moved the wires around with no reset before replacing them.  I guess I'll find out later this afternoon if that was the issue.
Quick update: It appears to have been an ESC issue. I installed new 20a Littlebees and all is well again.
  Help TX Sticks Control - Thumber vs. Pincher MacFly90 12 21,196 19-Oct-2023, 03:08 AM
Last Post: psfales
  Discussion Inav simultaneous wifi and RC control glassTransition 1 319 18-Oct-2023, 12:48 PM
Last Post: fpvapnea
  Help Help needed - blackbox file samples to finetune Flight time prediction model whiterabbit 1 231 25-Jul-2023, 12:20 AM
Last Post: whiterabbit
  Help Out of control rayb106 6 513 20-Jan-2022, 11:36 AM
Last Post: rayb106
  RX Loss flag and control without transmitter mwon 1 782 25-Oct-2021, 12:57 PM
Last Post: kafie1980
