Threads: 265
Likes Received: 2,610 in 1,545 posts
Likes Given: 3,893
78 How does the composition look for a build below?
XHover Stingy frame
DYS FIRE 2206/2600kv motors
XSD30A V2 ESC
CL Racing F4S Flight Controller
TBS UNIFY PRO 5G8 HV VTX
DSMX Quad Race Serial Receiver with Telemetry
RunCam split 2
Is everything compatible? Decent products? Things I should change based on performance or quality.
Thanks
Threads: 125
Likes Given: 99
388 There was supposed to be some issues with the Mach 2 VTX where it didn't properly implement smartaudio protocol correctly. I am not sure if that has been resolved. This is the reason I didn't not list it.
Threads: 265
Likes Given: 3,893
78 Thanks for the critical eye.....I will make some changes.
Threads: 265
Likes Given: 3,893
78 I noticed the xhover frame doesn't have a stack mount for the FC. etc....where do you get those? Would the Armatten Chameleon or Rooster frame be better?
Threads: 265
Likes Given: 3,893
78 Thanks for the info on the mach2 or AKK...
