Threads: 7
Likes Received: 4 in 4 posts
Likes Given: 18
0 I'm gonna be building a long range quad this spring so I'm getting all my parts in order currently. I know that I want to make 2 6s 4000mAh li-ion packs. I decided I didn't wanna buy the pre made packs because it's more expensive and it's nice to get the experience. I was wondering how do you actually know what type of mAh you'll be getting when wiring them up and how to go about picking the right cells.
Threads: 30
Likes Received: 411 in 310 posts
Likes Given: 325
19 Getting a cheap spot welder is a good way to reduce the risk involved in making your own packs. As for cells, I tend to get the Sony/Murata VTC6, Molicel P42A, or Samsung 50S. Just make sure to keep your amp target below 50% of what those cells will crank out continuously, or the energy density will be wasted on efficiency losses. If you need more amps in your voltage target, do them in parallel.
Threads: 76
Likes Received: 1,393 in 1,044 posts
Likes Given: 813
41 Simple Spot Welder tutorial that might be of use.
Try Not, Do or Do Not
- Yoda
Threads: 203
Likes Given: 306
11 I have soldered like the video shows with nicads,nimh,A123, and 18650,21700,etc…
Threads: 1
Likes Received: 22 in 19 posts
Likes Given: 51
0 Very easy to make if you are competent with soldering. If not, best to leave it to someone else, or buy them ready made.
Threads: 7
Likes Given: 18
0 Figured I should probably update, on this. I did end up making my own and it was pretty easy. I used the nickel strips to keep everything nice and flat. I used the soldering method and the number one thing that made it easy was roughing up the surface of the batteries. I just used a dremmel to rough it up and that makes the solder stick really easily and really well, then I just tinned the nickel strips and pressed them onto eachother. Wasn't able to break the joint with any amount of force after that.
Will definitely make more lithium ion packs in the future!
