"Lightest" motor for 6" or 7" LEAF
I'm still shopping around for parts for my "LEAF"
6"/7" toothpick build. There are new props and motors now:
Intended props:
GF 6026
Avan 6038 - https://www.racedayquads.com/products/em...53eb&_ss=r
GF LR 7035 - https://www.airbladeuav.com/collections/...p-set-of-4
Motor:
Amax 2305.5 23g!?
https://www.racedayquads.com/products/am...50kv-motor
Flywoo 2303.5 21g
https://www.racedayquads.com/products/fl...295f&_ss=r
Lumenier Chief 2005 17g?
https://www.getfpv.com/lumenier-2005-200...motor.html
T-Motor 2203.5 17g.
probably too small.
I'm leaning towards the $15 Amax due to the $20 cost of Flywoo, and my ehem.. quality issues.
Customer support is friendly, the NIN 1404 is good, but I have drawer of dead AIO FCs.
Hi Roman!
I'm also working on the same goal - a lightweight 6-7" frame that flies loooooong (20min+ with a naked GoPro) - but great - while using the DJI digital FPV system. I've been designing a few prototypes of frames that are trying to find a sweet spot between stiffness and weight. My latest designs end up at aroung 70g for 6", and 100g for 7".
I was starting out with 2004 motors and sub250g on a 7" - i couldn't get it to fly halfway decent.
Then i switched over to a 6" frame and 2203.5 T-Motor with 1500kv. This was working quite well, but with 4s Li-Ion and 350g AUW i was only getting around 20-25mins of flighttime. With a naked GoPro more like 15-17. I probably would be able to save another 20g or so, but i don't think this will drastically change the picture.
I fear that the switch from 2203.5 to 2303.5 won't provide much better results than what i got. Also is recommend lower kv numbers (1500kv and below). However tt really depends on your overall AUW and the cell amount. Can you provide a little more information what you've got planned for your build?
My next approach will be trying out the iFlight Xing2 2604 motors with 1350kv on 7". With 32g (+ around 3g for a longer wire) these are still much lighter than the usual 2806 motors used on large LR rigs.
Hi, i’m Nic and i design frames for fun :-) check out my YT-channel for all my works and projects:
https://www.youtube.com/c/eyeflytinkerings
the brotherhobby 2004 will be the most lightweight option.
there is the hglrc 2105, which won be the lightest but might be a good size for 6inxh
Chris Lemire got like 30min+ with Mamba 2204 1400KV.
By far, I think the super light carbon fiber 7035 props give the advantage.
His 7" toothpick got under 250g AUW with battery, with Brotherhobby 2004 - but didn't fly too good.
His recent video is using StanFPV 2604. Nice big EZO bearing. But, these are very very expensive.
I have the FPVCycle2204, but using them on PodRacer5".
For 7", I think I need motors closer to 30g.
Right now, my gut is saying to go with reliable smooth Smoox 2306.5
  5" Mid range motor sizing help B4tn 4 410 01-Mar-2024, 12:25 AM
Last Post: B4tn
  Motor size blackhole durachoke 5 1,271 16-Jan-2022, 03:52 AM
Last Post: BigBeard
Question Motor selection for a 7inch - Medium range mountain surfer PeladoMat 24 3,757 16-Aug-2021, 12:30 AM
Last Post: BigBeard
Lightbulb Help FR7 v5.1 Custom motor mix Myman 10 1,099 27-Jun-2021, 12:40 PM
Last Post: kafie1980
  T-Motor 1404 ... 2800KV the.ronin 0 683 29-Mar-2021, 07:13 PM
Last Post: the.ronin
