Threads: 8
Likes Received: 0 in 0 posts
0 I hope this is the right place to post it.
I've just built my own 4s battery based on Liitokala 3.7V 3000mAh 18650 VTC6 cells. No actual flying done just yet but a hoover test. I didn't time it but for sure lasted longer than my 1500Mha lipos.
What I noticed though was that the drone would disconnect from my controller and the goggles when heavy on throttle at the end of the battery .
My question is - would it be safer to run 6s battery to make sure DJI unit gets its 9v constantly, even when the battery is being close to its lowest voltage.
Also is discharging to 2.5v safe?
Threads: 14
Likes Received: 163 in 126 posts
Likes Given: 1
12 It might help butvthats a big weight penalty for another 2 cells. Voltage sag is an issue with lithium ion, I like to up it 1s over what I'd run for a lipo where practoval but youl still experience voltage sag and it can be pretty extreme at the end.
These don't have a very high c rating, usually about 1.5c recommended discharge rate. That should equate to a 45 minute flight time and no one's really achieving that for 4". So can you go safely to 2.5v? Maybe. Lots of people run to 3.1 volts or so but the full rated capacity is generally to 2.5v and is considered safe. But only when they are not being discharged wildly fast like we do. I do it often enough but I'm hardly maintaining flight at that point I'm just doing a low creep back keeping the amps as low as possible.
The larger size 21700 have a much higher discharge rate I haven't tried any yet but aside from 4" the's will probably be all that I buy going forward for 5" and up if they prove to perform better for multirotors.
Threads: 8
0 26-Nov-2020, 09:07 AM (This post was last modified: 26-Nov-2020, 09:11 AM by pattap.) I never thought of 5s but I like the idea. I guess it would allow for a good balance between the weight and the minimum voltage allowing the airunit to stay on when the battery fully discharged.
Also the cells discharge is rated as 30a, am I right in saying that the discharge rate would be 1c?
Threads: 14
Likes Given: 1
12 That would be 10c for 30A discharge rate.
Threads: 22
Likes Received: 4 in 4 posts
Likes Given: 2
0 Funny, I was just looking to lion last night. But I would need a 6s. The weight and cost seams not worth it. Maybe in a couple of years when 6s is more prevalent.
