KAKUTE F7 FLIGHT CONTROLLER - Steel Screws?
Hi Everyone,
Has anyone used M3 steel screws for their Kakute F7 FC? I have searched for literature on this particular FC but cannot find whether it will short it out or not, any guidance is appreciated.
Thanks!
The easiest way to check is use a DMM. On continuity mode, check if the metal ring around the mount holes are connected to the ground. If it is not, then you can use metal screws. If it is, then I would consider using nylon screws.
  • stuart.hembree
The metal ring around the screw hole is connected to ground (just like most FC out there).
It shouldn't cause a short using metal screws, but i would advice against it because it doesn't use rubber grommets.
For the Kakute F7, nylon hardware is better because it can take the impact in crashes, and break in extreme cases. With metal screws, the impact will completely pass on to the board and more likely to damage it.
  • roger74, stuart.hembree
See the video below that was posted by JB yesterday. However, take note of what Oscar said regarding lack of shock absorbtion. As they say, the choice is yours Smile
  • stuart.hembree
Grounding to frame doesn't effect the quad. But now you made a bigger ground plane. Especially on crash or loose wire, there is a higher chance for short. I make it a habit to avoid it if I can.
Just saw this, thank you!
  low flight times on 3.5 cinewoop technoflyer97 2 135 03-May-2024, 09:16 AM
Last Post: technoflyer97
  Flight time decreased Billybobthe3 8 230 01-May-2024, 10:57 PM
  problems connecting and writing code for the remote (esp32) and the flight controller YarikVor 2 159 23-Apr-2024, 03:58 PM
Last Post: YarikVor
  Can I connect my DJI fpv v2 goggles to and dji fpv remote controller 2 to other drons qt179 4 281 08-Apr-2024, 10:57 AM
Last Post: roleyrev
  After 1-2 minutues of flight, drone flips over in air doublebubble 22 875 16-Feb-2024, 11:32 PM
Last Post: mstc
