So, the non-inverted signal is much more complex than I initially thought. On most Frsky receiver, the non-inverted signal is simply tracing the signal to the IC that does the inversion. Unfortunately, I was not able to get to the bottom and find a solution before my receiver shorted. But I did find a few very interesting things. Stick movements was not an issue. It was the telemetry. I tested on a CLRacing F4 that has inverted UART TX for tele and a bidirectional normal UART.
From the Fport pad, the trace splits and goes to two different C04R chips. It looks like one is input and the other output.
If I wire to the Fport pad to a bidirectional UART (hardware inverted), I was able to get RSSI to return to FC automatically. When I bind to my Horus, I also got Vfas, A4 (per cell voltage), and A1/A2 (don't know what this is). When I bind to my Radiomaster with the multiprotocol, I get A2 (but the voltage is incorrect), TRSS, TQly and RSSI. Overall, the telemetry sensors are much less than a true Frsky receiver.
With the Horus, the receiver also return the RSSI on Aux 12 automatically. With the RM, there was not RSSI on Aux 12. It seems that the multi-protocol still is not perfect.
When I wired to the output of this C04R, I only get RSSi to return to FC automatically, but I don't get Vfas.
On the RM, I was only able to bind on Frsky D16. The "Frsky D16 clone" choice did not bind.
Somehow I shorted the MCU. So that was the end of my experiement.
