Hello,
I got into FPV a bit ago and have been flying analog. My VTX is the GEPRC RAD 1W on the Cinebot 30. My goggles are the EV800D with stock antennas. I don't expect phenomenal range with this set up, but my last couple flights have had really poor range, approximately 100-200 ft. I've had better range in the past, so I'm not sure what has changed. I looked around the internet and heard changing power output or channel could solve the problem. I am thinking it is possible my Vtx is set to an output of 25mW, and is causing poor range. I tried upping the power output through betaflight, but I struggled to get Tramp to work. I had my quad plugged in to my computer as well as my battery plugged in. My Vtx was powered up, but the Device Ready option in the Video Transmitter Tab read "No." I watched a JB video and was told that had to say "Yes" in order for it to communicate with the Vtx. I confirmed everything was wired up to the correct port, and cannot understand why I am having troubles. I then tried changing output and frequency through my OSD in my goggles, however when I save the settings and return to the menu, the power seems to be return back to 25mW.
I will try to attach any pertinent photos and screenshots, but I am new to the forum, so if there is anything else that would be helpful to see/know I'd be more than happy to provide it.
Thank you in advance for your time and assistance.
