INAV set
OK i need the advise and help of the experienced builders out there..... still trying to understand INAV.... wanting to know is this setup possible... the betaflight F4 Fc only has 4
PWM pads i see PWM 5 & 6 but how do they get power ?  this is going on a wing with steerable nose gear....  and retracts.. can i connect  SBUS, THR, L-ELEVON & R ELEVON and rudder (STEERING) to the FC ???? and connect the retract servo straight to the receiver ???? like the picture [Image: 0UHEuusl.png]
You can use an sBus to PWM decoder, it'll give you 4 pwm outputs
https://hobbyking.com/en_us/frsky-4-chan...tore=en_us
(27-May-2018, 04:27 AM)RENOV8R Wrote: You can use an sBus to PWM decoder, it'll give you 4 pwm outputs
so im taking thats a "NO" it wont work !    and on that board,  what is PWM 5&6 used for ? and how are they connected since its just a signal pad !!!!!  where do you get the power and ground from???  ( the 5v and gnd other side of the board)
RENOV8R   will this work as well.....https://www.youtube.com/watch?v=jUkutJrzXFI
  INAV Sensors Barometer GiantsFan5 1 97 02-May-2024, 05:46 PM
Last Post: PeladoMat
  INAV Angle mode problems RConcienne 1 118 18-Apr-2024, 04:17 PM
Last Post: segler999
  Beginner FPV set for former RC heli pilot ITManuel 7 251 03-Apr-2024, 08:54 AM
Exclamation iNav Install I Question.... Coleon 15 438 23-Feb-2024, 07:31 AM
Last Post: fpvapnea
  Inav config Pumpkin head 2 337 27-Nov-2023, 01:37 PM
