09-Feb-2020, 01:37 AM
Using a 722-Wing FC with a FrySKy R9 Rx.
FC arms and all servos appear to work perfect.
Manual, Horizon, RTH all set up on a 3-position switch and everything appears to work fine.
Have Arming set up on Channel 6 in Taranis X9D Plus using S2 Knob and Arming set up on Channel 6 in "ARM MODE" in FC and it works fine.
However, I set up Nav Launch on Channel 6 as well but as I use the S2 knob and roll through the bracketed block for Nav Launch it will not arm but as I roll it on past it and into the bracketed block for ARM it will actually arm.
Cannot figure out why NAV LAUNCH will not arm.
Appreciate any advice, suggestions.
Thanks.
Thanks.
