31-Mar-2019, 03:01 AM
I've been flying for a little while now, everythings worked perfect up until today. I have an Armattan rooster 6, with a crossfire, and a unify pro. After flying i brought my drone inside to turn the power up on my unify pro, something id never gotten around to doing. Got it up, exit betaflight and now my quad wont arm. I've tried re locking the unify and various other things to try and fix the problem. cli says rxloss is the issue but my crossfire has a steady running link. And the receiver tab in betaflight is completely unresponsive to any control inputs, all while crossfire has a running link. FC no longer has a blinking green light when powered, and only beeps once before the long beep during initial startup, as opposed to its usual two quick beeps followed by one long beep. I've tried flashing firmware through betaflight, i get an error stating no response from the bootloader, flash failed. AND the obvious one, but being relatively new i want to make sure none of the other factors were contributing to the problem as well, my radio (taranis qx7) will drop rx signal all together (displayed on radio), then just a second later it will come back full power. The physical crossfire device never turns off, and displays a running link the entire time which leads me to this confusion.
Does anyone have any advice?
