HS1177 FPV Camera Review
[Image: R68uOfTl.jpg]
The HS1177 FPV cam is one of the most popular fpv cams out there.
What makes it so popular?
The fact it is small, all self contained in a protective case
Lightweight
Easy to set up
Accepts a wide range of input power, 5-17 volts
Has it's own mounting cradle.
Fits on mini quads real nice
Adjustable Tilt
Tons of 3D printed case.Holders, mounts etc available should you want to print your own.
Cons:
The metal cradle while adjustable with 3 position holes is sadly a weak link, the metal is almost as soft as butter and breaks really easily.
The Configuration cable is not the best and requires you to purchase third party items to actually be able to change any settings on the camera, Or be a dab hand at soldering to make your own custom connections.
Overall it is a great camera, handles light changes very well and because of it's small form factor and being light weight it is suitable for a wide variety of multirotor sizes.
NOTE***
While the camera can accept 4S voltage it is not recommended to attach it directly to 4s as mini quad esc's do spike at times and may push the cam over it's voltage limits, Always use a line filter on your FPV gear.
[Image: 4AucnRGl.jpg]
Specs:
  • CCD: 1/3” Sony SUPER HAD II CCD
  • Pixel PAL: 976(H) x 494(V)
  • NTSC: 768(H)×494(V)
  • TV System: PAL/NTSC(according to country)
  • Resolution : 650TVL(b/w), 600tvl(color)
  • Synchronization: internal synchronize
  • Shutter Speed (CCD IRIS) PAL: 1/50~1/100000 sec; NTSC: 1/60~1/100000 sec
  • Noise: > 60 (AGC OFF)
  • Video Out : 75ohm, synchronize
  • Min. Illumination: 0.01Lux
  • Auto Gain: Off/Low/Mid/High
  • Back Light Compensation (BLC): Off /Back light compensation/ Strong light suppression
  • Private shading (PRIVACY): 1~8 private shading area
  • Motion Detection (MD): On/ Off (Multi level sensitivity settable)
  • Auto White Balance: Manual / Auto / Auto track
  • Mirror : Horizontal Mirror optional
  • Negative : Positive / Negative optional
  • Color to B&W: Auto
  • DNR : 2DNR
  • WDR: D-WDR
  • Day / Night Shift : Auto/ Color/ B&W
  • Menu (OSD): English menu
  • White Dot Repair: Support
  • Image Adjustment: Support
  • Camera Title : Support
  • Power Requirement : DC5V~17V
  • Working Temperature : -10 C ~ +50 C
  • Working Humidity : 20~80%
  • Storage Temperature : -40 C ~ +60 C
  • Storage Humidity : 20~95%
  • Dimensions(mm) : 25X25(W*L)
  • Power Consumption: 70mA
  VTX Quanum Elite QE58-2 5.8GHz 25-200mW VTX: Bench Review & RF Power Measurements Michael Grabner 3 2,524 03-Jan-2024, 02:31 AM
  orqa fpv.pro ? hugnosed_bat 3 495 22-Sep-2023, 01:03 AM
  Surprise! Looking for free trial fpv player! ifpv much 0 326 08-Feb-2023, 08:52 AM
Last Post: ifpv much
  Is it possible to build an fpv drone within 150 dollars? ifpv much 31 2,114 08-Dec-2022, 06:54 PM
Last Post: burkeomatic
  Full MSP OSD for DJI FPV System - Now available! V-22 16 5,586 05-Dec-2022, 04:35 PM
Last Post: fpvapnea
