Threads: 13
Likes Received: 4 in 4 posts
Likes Given: 13
1 Does anyone know the method to setup my quad to beep BOTH the motors AND ESC on a switch in case it is lost? I have it setup on a switch now in Betaflight modes with the beeper mode but ONLY the ESC beeps. I had it working with BOTH going before and updated ESC and now only the ESC is beeping. It was MUCH louder with ESC and motors beeping. I have a TX16S radio.
Threads: 596
Likes Received: 9,039 in 6,690 posts
Likes Given: 1,428
796 I'm not sure what you mean by both the motors and ESCs beeping. The ESCs have no capability to beep. Only the motors do.
Does your quad have a real buzzer installed?
Threads: 31
Likes Received: 208 in 158 posts
Likes Given: 95
14 ESCs don't beep. I guess you are talking about buzzer and motor beep. You want to beep both. Try to set rx set ON that is located on the configuration tab.
Threads: 172
Likes Received: 2,299 in 1,845 posts
Likes Given: 4,755
103 in betaflight configurator, scroll down and "dshot beeps" "set"on
Threads: 31
Likes Given: 95
14 On the configuration tab you have the option RX_SET. Put that option ON. Both will beep.
Threads: 13
Likes Given: 13
1 Wow that was it!!!! Thank so much to both of you Hugnosed and Maiden!
