07-Feb-2020, 06:53 AM
Hi All,
I am a newbie practicing indoors with micro whoops.
I have a TinyHawk 2 and pretty happy with the way it flies and turns, it seems to have excellent yaw stability, i.e. it can make 180 deg turns almost on a dime. These are on stock settings in angle mode.
I recently purchased the GepRC CineEye. This one seems to drift quite a bit on large yaws, more so when the yaw rate is slow, and I tend to lose control and hit a wall or something when making 180deg turns. Again on stock settings in angle mode.
Is it possible to tweak yaw stability using Betaflight?
Thanks in advance.
Thanks in advance.
