02-Dec-2019, 03:18 PM
Hi guys my pdb burned up,how can i check the motors to see if they work before rebuilding the quad. I have an idea of connecting a 12v. bat. directly, is that a good idea they don't look burned.
THANKS
THANKS
![[Image: oBnPpZrl.jpg]](https://i.imgur.com/oBnPpZrl.jpg)
HOW TO CHECK MOTORS |
02-Dec-2019, 03:18 PM Hi guys my pdb burned up,how can i check the motors to see if they work before rebuilding the quad. I have an idea of connecting a 12v. bat. directly, is that a good idea they don't look burned. THANKS ![]() 02-Dec-2019, 03:29 PM (This post was last modified: 02-Dec-2019, 03:49 PM by SnowLeopardFPV. Edit Reason: Added video link. ) Unfortunately you can't just connect brushless motors up to a voltage to check if they work or not because they are 3-phase motors requiring pulsed voltage phases. You either need to connect them to another ESC which in turn is connected to a flight controller to test them, or you will need to use a "Servo Tester" and an ESC which will provide the require phased voltages to the motor to make it spin. Either way you're going to need a working ESC in order to test a brushless motor. Lee has a good explanation about how ESCs use phased voltages to control a motor in the video below. Everything up to about the 6 minute mark should be enough to show you how things work. Beyond that it starts getting into ESC firmware capabilities and types. 02-Dec-2019, 05:43 PM (02-Dec-2019, 03:29 PM)SnowLeopardFPV Wrote: Unfortunately you can't just connect brushless motors up to a voltage to check if they work or not because they are 3-phase motors requiring pulsed voltage phases. Thank you my freind you are allways helping out. 03-Dec-2019, 02:07 AM You can actually check your motor without ESC. Little bit cruel, but works. 04-Dec-2019, 04:59 AM you could physically inspect the windings by removing the bell and looking... when the coating on those windings burns its its usually very obvious, they bubble up almost and turn a dofferent color and smell bad... even if they havent smoked.... its obviously not 100% though but if you jist need that extra little push of confidence this could do it for ya. 'Ignore' is the route word of Ignorant. |
one of my Cetus pro motors died, will this be a good replacement? | hananelroe | 1 | 117 | 27-May-2024, 08:49 PM Last Post: Pathfinder075 | |
MOTOR_PROTOCOL flag, motors won't spin when armed, & more | freezyfpv | 2 | 228 | 18-May-2024, 11:48 AM Last Post: SnowLeopardFPV | |
Very inconsistent motors/ARMING | tenaciousFPV | 7 | 352 | 15-May-2024, 04:11 AM Last Post: husafreak | |
Why do higher voltage batteries need lower KV motors? | Eyes.fpv | 1 | 208 | 04-May-2024, 01:42 AM Last Post: SeismicCWave | |
Motors not responding to transmitter input(no airmode) | corwin | 1 | 174 | 22-Apr-2024, 05:07 PM Last Post: mstc |
