21-Apr-2021, 07:28 PM
Hi, I read a few posts regarding "How tight should the propeller nuts be?"
Some suggest that I refer to the specs of my drone. What I got is a iFlight Nazgul5 V2 240mm 5 Inch 6S Freestyle FPV Racing Drone. Not much specs there.
On my first flight, one screw came right off and lost in the grass ground. I should definetly tighten it better but I am not sure if I should tighten the nuts as much as possible, because I am afraid that would be damaging the motor. So what you guys thoughts on this?
