Phantom on 4.1.1 decided to upgrade to 4.1.7 (last 4.1 version).
Flashed with "full chip erase " deselected and "no reboot sequence" deselected.
The "Flashing" yellow bar is now stuck at around 50% and nothing happens.
FC only has one red LED on.
What can I do?
Here is the log on top of BetaFlight
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Serial port [color=var(--accent)]successfully[/color] opened with ID: 6[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- MultiWii API version: 1.42.0[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Flight controller info, identifier: BTFL, version: 4.1.1[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Running firmware released on: Nov 15 2019 12:55:17[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Board: MATEKF411(STM32F411), version: 0[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Unique device ID: 0x2e00423439510a38313437[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Craft name: PhantomRJA[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:40 -- Arming Disabled[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:43:42 -- CLI mode detected[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:27 -- Serial port [color=var(--accent)]successfully[/color] closed[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:29 -- Using cached builds information for jobs.[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:29 -- Using cached release information for firmware releases.[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:30 -- Using cached release information for firmware releases.[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:50 -- MultiWii API version: 1.42.0[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:50 -- Device - [color=var(--error)]Rebooting to ROM BOOTLOADER[/color][/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:51 -- USB device [color=var(--accent)]successfully[/color] opened with ID: 1[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:51 -- Detected device with total flash size 512 KiB[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:51 -- Read protection not active[/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:44:59 -- Erased 496 kB of flash [color=var(--accent)]successfully[/color][/color]
[color=rgba(255, 255, 255, 0.6)]2020-10-04 @ 10:45:26 -- USB device [color=var(--accent)]successfully[/color] closed[/color]
What can I do?
