Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 Hi All Yet another newcomer... Acquired a DARWIN FPV BABY APE V2 PRO with ELRS rx the PNP type. Can't find anywhere which elrs device is installed. On power up I see a red blinking led on the fc which is a Iflight f411 pro. Also a yellow double flashing led. As supplied by unmanned tech fpv in the UK. I need to bind to a Radio master Zorro ELRS which has an internal elrs module. No way can I do it. I can bind the Zorro to a betafp micro ELRS rx after flashing the Rx with latest elrs firmware with my bind phrase. I can't flash the babyape elrs Rx because I don't know which device to select in elrs configurator. Tried betafp nano Rx but that failed to flash. Can anyone tell me how to proceed please? • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 11-Sep-2023, 07:54 PM (This post was last modified: 11-Sep-2023, 08:04 PM by Lemonyleprosy.) I’m a bit confused, and need a bit more information to help you. If you bought the PNP version, this is “plug and play” which means it does not include a receiver, and you need to supply and install your own. If this is the case, what ELRS receiver did you purchase? If you bought the ELRS version of the baby ape pro, then this comes with the DarwinFPV 15A ELRS aio, which has a built in spi based ELRS receiver. That board has an spi receiver, which means you can’t flash it separately. Spi ELRS support is baked into betaflight, so you’ll have to install the correct betaflight version in order to make the spi receiver on the aio match the elrs version that is running on your transmitter. (Betaflight 4.3.x for elrs v2.x, betaflight 4.4.x for elrs v3.x). If flashing the latest firmware allowed you to bind to your other ELRS receiver, then you are likely running ELRS v3.x on your Zorro, which means you’ll need to update to Betaflight 4.4.x on the DarwinFPV flight controller using the BETAFPVF4SX1280 Betaflight target, at which point you should be able to enter your bind phrase in the receiver tab of betaflight and all should be well. That’s all supposing that you have the built in ELRS version. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 Thanks so much for your quick reply. Sorry I meant BNF not PNP. I paid extra for the elrs version rather than FRsky or no Rx. Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 Okay. Yeah, you’ll need to update to betaflight 4.4.x, then enter your binding phrase on the receiver tab and you should be good (after also setting up your modes and other settings). Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 I find this confusing sorry. I did a diff all command in cli and got the info that the board is Matek 411 Betaflight version is stm32f411(S411) 4.2.5 • Posts: 2,074 Threads: 68 Likes Received: 1,156 in 839 posts Likes Given: 105 Joined: Jan 2023 Reputation: 59 (11-Sep-2023, 08:16 PM)Lemonyleprosy Wrote: Okay. Yeah, you’ll need to update to betaflight 4.4.x, then enter your binding phrase on the receiver tab and you should be good (after also setting up your modes and other settings). That's only if your radio is on ELRS 3.x, if you are still on ELRS 2.x then you have to stay with BF 4.3 or below which is probably what came preflashed on the AIO. In that case you just have to type the binding phrase UID in the CLI https://www.expresslrs.org/hardware/spi-receivers/ • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 The auto detect in firmware flasher says matek411 Should I change this to betafpvf4sx1280? And do I need to power up the babyape in boot loader mode before I go flash firmware? • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 11-Sep-2023, 09:00 PM (This post was last modified: 11-Sep-2023, 09:01 PM by Lemonyleprosy.) Hold on. I may have given you incorrect information, they may actually be using a different flight controller and an external receiver on the v2 baby ape pro. Can you take the top deck off the quad and post a clear pic of its electronics? Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 11-Sep-2023, 09:13 PM (This post was last modified: 11-Sep-2023, 09:14 PM by PJKMBAKER.) If I select betafpvf4sx1280 and go to flash firmware I get a warning that there is a mismatch as the board is matek411 and should I abort or continue flashing. Ok I will take the top deck off. 15 mins. Thanks • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 I have a good picture but don't know how to post it here • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 11-Sep-2023, 09:56 PM (This post was last modified: 11-Sep-2023, 09:57 PM by Lemonyleprosy.) (11-Sep-2023, 09:46 PM)PJKMBAKER Wrote: I have a good picture but don't know how to post it here Hit post reply, Click on the little Imgur button. Don’t continue the flash, don’t flash it until we can confirm what you actually have Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 2,074 Threads: 68 Likes Received: 1,156 in 839 posts Likes Given: 105 Joined: Jan 2023 Reputation: 59 Per the DarwinFPV website, BAII now comes with a 3-6S Flight stack and external ELRS nano RX (wow and 1504 motors too). • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 Here is a picture of I manage to attach it • Posts: 193 Threads: 31 Likes Received: 3 in 3 posts Likes Given: 2 Joined: Sep 2023 Reputation: 0 11-Sep-2023, 10:13 PM (This post was last modified: 11-Sep-2023, 10:13 PM by PJKMBAKER.) Nope can't get the picture posted What is an Imgur button? • |
