Help! Can I test ESC
So I did this to my flight controller and I'm just wondering if there is a way to test the 4 in 1 esc to make sure it is still good.  Apparently when I soldered on the receiver wires I shorted something out and had flames.  I don't even know if the receiver is still good.  Beginner woes Sad
[Image: CSdNnWd.jpg]
if it doesnt smell about smoke... i guess it should be fine. you can plug in the battery to the esc without an fc, hear the first beeps from the esc as a first test...
same with the receiver... there is no simple sort of testing, another fc are needed to try them
(24-Dec-2019, 07:21 PM)hugnosed_bat Wrote: if it doesnt smell about smoke... i guess it should be fine. you can plug in the battery to the esc without an fc, hear the first beeps from the esc as a first test...
Thats kind of what i thought after searching the net, but i was hoping.  Is there  any worries of frying my new fc when it comes if the esc or receiver are bad?
  ESC, UBEC information tranhuuanhtu02 7 162 26-Jun-2024, 11:15 AM
  Motor/esc problem Axel 42 1,252 26-May-2024, 10:15 AM
Last Post: wizofwires
  How to determine which protocol to use between ESC and RC? brushlessman 2 169 07-May-2024, 03:32 PM
Last Post: V-22
Question Is it possible to test if an ESC works without soldering? HypnoToad 2 227 23-Mar-2024, 07:22 PM
Last Post: HypnoToad
Exclamation Noob Question..... "VTX/ESC" Boards.... Coleon 12 559 02-Mar-2024, 12:35 PM
Last Post: Luk5569
