Hd-Zero sbus on soft serial?
Looking at my 4” Recon build.. going with a 20x20 stack(Darwin).. the FC’s Uarts are usb vcp-uart1-uart2-softserial1…. In the configurator it shows the SS1 with (vtx-tbs smart audio) already enabled.. I was wondering if I could use this as sbus for the Hd-zero vtx…
Come to think of it… I have to still locate this pad on the FC… just curious as this fc also has a Micro SD slot for black box.. .. I have never used a SS to a uart.. I think I saw Bardwell explain it once…
I pulled the pinout on that fc up.. Darwin has sbus marked clear as day.. just above the rx1-tx1-rx2-tx2 I think I answered my own question ..
(04-Aug-2023, 06:37 PM)Rob Axel Wrote: I think I answered my own question ..
I think you might have as well.
  FC SBUS Out Rotems 2 307 18-Oct-2023, 09:00 PM
Last Post: Rotems
  I made some soft mounts - now I need input xcalibur 14 2,008 04-Apr-2018, 09:44 PM
Last Post: xcalibur
  Help X4R-SB doesn't bind with Taranis SBUS Oscar 1 1,755 06-Nov-2017, 07:46 PM
Last Post: raspberrypi33
  Soft Serial for SmartAudio on Kombini DS? JBFUK 11 3,348 02-Oct-2017, 07:14 PM
Last Post: voodoo614
  Discussion Soft mounting FC/motors oyvinla 28 18,456 12-May-2017, 07:58 PM
Last Post: Kleinerbug_FPV
