Threads: 121
Likes Received: 24 in 23 posts
Likes Given: 490
0 Hello, i have took that flux from aliexpress and is hard like rock, is it normal ? can be used anyway in this way ?
maybe because it spend a night in the post box outside with very low temperature ? maybe not because don't melt even if now i'm keeping under the stove, just receive a bit of warm...i will not burn it to smell deadly smoke ;
Threads: 77
Likes Received: 2,550 in 1,859 posts
Likes Given: 3,959
121 11-Jan-2023, 07:50 PM (This post was last modified: 11-Jan-2023, 08:01 PM by Lemonyleprosy.) That kind of rosin is great for cleaning your tip, but it’s not what you want for soldering.
You want a flux paste or liquid flux for soldering.
To use what you have to clean your tip, heat up your iron, press the tip into the rosin and give it a little twist to coat it, then wipe it on your brass wire sponge, then re-tin the tip with some solder.
Dangerous operations.
Threads: 596
Likes Received: 9,039 in 6,690 posts
Likes Given: 1,428
796 You can use hard rosin when soldering as demonstrated in the video below but it's not convenient to use like this so you will be much better off (and have a much easier time) if you just get yourself some proper no-clean liquid soldering flux.
