Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 0
0 Can i connect a USB powerbank to my FC so my GPS can track the sat's?
When the min. 8 sat's are found then i connect the flight battery en after that i disconnect the USB powerbank.
Is that an option?
Threads: 1
Likes Given: 0
0 Ok Thanks, so my phone will also work. Great!
Threads: 9
Likes Received: 8 in 8 posts
Likes Given: 3
0 you could consider a vifly GPSmate...?
Threads: 172
Likes Received: 2,297 in 1,844 posts
Likes Given: 4,752
103 exactly the steps as mentioned above, exept power by battery while plugged in with the usb.
it wont fly after usb power without power it again. it wont have the sats directly, just a warmstart- it should get the satelites found bevor in short time, it should take less than a minute for a 3dfix.
depending on the location, it can be difficult to get 8 satelites on the ground, i suggest to set the min sats lower toer, to the minimum of 5 sats.
