Threads: 28
Likes Received: 29 in 17 posts
Likes Given: 22
1 hi
im still learning
i wanted to test gps rescue
i waited till gps fix
i flown away 250m
pressed button
and it was not going into my way at all
it flown up a bit - normal
and then it was going not into my direction at all - it was going left from home position
what can be a problem ?
thanks
Threads: 2
Likes Received: 6 in 6 posts
Likes Given: 15
0 Do you have enabled "direction to home" in your OSD? If yes was the arrow showing in the right direction as you started to fly away? How many satellites did you had at start where the home point was set?
Threads: 28
Likes Given: 22
1 yes i have direction to home and while i was flyying myself direction was ok
i do not remember how it was after enabled gps rescue
on homepoint set i had 8 satelites
Threads: 2
Likes Given: 15
0 Are you using betaflight? Can you share your settings? Maybe a "diff" or "dump".
Threads: 2
Likes Given: 15
0 05-May-2021, 11:47 AM (This post was last modified: 05-May-2021, 11:56 AM by MelBourbon.) What GPS are you using? Can you send me what you get if you add "get gps" into the CLI?
Are you sure you have armed the quad only after there was a GPS fix? Because you have set 'gps_rescue_allow_arming_without_fix' to ON which allows you to arm without having a fix. So if you arm without a fix the home point may be not set correctly. I would recommend to set this to off and try again.
Threads: 2
Likes Given: 15
0 05-May-2021, 12:09 PM (This post was last modified: 05-May-2021, 12:10 PM by MelBourbon.) Could be the wind. Then you should wait longer and see if the copter corrects and really comes back to you.
But there is a gps option which, if set to on, sets the home point only once at the first arm after a lipo is added. Thats the reason why I wanted to be sure you had a fix at the FIRST arm. Because if this option is set it may be the case that, if you only shortly arm for testing purpose, disarm again to wait for the fix and arm again, the home point is set based on the first arm where the gps position may be not appropriate based on missing satellites. But I'm not sure if this is possible at all and if betaflight will set a home point at all without a fix.
Threads: 2
Likes Given: 15
0 In all of my cases the quad directly turned into my direction within seconds. So I don't think you need to wait longer. With that I currently don't have any glue except for checking the setting above and maybe try on a day without or less wind.
Threads: 28
Likes Given: 22
1 ok now when i have gps unit with magnetometer it is even worse i arrow is facing wrong / oposite to home direction
what may be the issue ?
i saw that some pepole have that issue when wrong font etc. im using dji system so not loaded any fonts etc ;/
Threads: 28
Likes Given: 22
1 05-May-2021, 07:52 PM (This post was last modified: 05-May-2021, 07:58 PM by d00lar.) i did calibration on magnetometer
i have flown 3times now 3arms and disarm
one of them was ok - arrow ok and gps rescue working... (second)
2 as prevouusly;/
