Threads: 13
Likes Received: 0 in 0 posts
0 Installed a BN220 GPS unit the other day. Works fine but there is one issue I am having when I change the drones battery. That is I loose all the satellites and have to wait up to five minutes between every battery change for the GPS to find more satellites.
Has anyone else had this issue? I noticed a small watch type battery on the GPS and was under the impression this would supply power to the GPS to retain all the satellites in its memory, thats the only purpose I can see for the battery to be there. So maybe this battery has been discharged? Are I on the right track here?
Threads: 129
Likes Received: 2,740 in 1,644 posts
Likes Given: 2,969
65 This is normal until that little backup cell takes a charge. I have three of those GPS units and two of them act the same way you describe until they have been powered for about 20 minutes. You can always supply 5vdc from an external source to the unit and let it charge that way. The plug in USB chargers supply 5vdc, you could mock up a cable with just POS and NEG and let it charge for a bit.
In the end, those little units work, but after a year of having to fiddle with them to keep them working correctly I replaced them with the Matek GPS units and those always work without issue.
SoCal Kaity :D
OMG, no one told me it would be this much fun! Addicted :)
Threads: 129
Likes Given: 2,969
65 I wonder if maybe some of those little units made it out for sale with failed aux power (that little cell that allows for "warm starts").
The one on The Japalura is slooooooow. The one on the 5" is fast like you are are describing. Both are were installed within a week of one another. If I swap the units, the issue shows follows. It is definitely the units, but no rhyme or reason for it.
waynepatt58, you might contact the vendor and ask if they will replace the unit as the one you have is faulty?
SoCal Kaity :D
Threads: 265
Likes Received: 2,610 in 1,545 posts
Likes Given: 3,893
78 I agree with Kaity, try to get a replacement.
Threads: 13
0 thanks for all the comments, I will try to charge the cell up to see if it corrects the problem.
