hello all!
i am considering two frame mounting options of my HGLRC M100 MINI gnss module. please see pics below:
my initial experience with the M100 mini has been excellent so far! it came as you see in the pics with the 200cm cable soldered in place. i just repositioned the 4-pin wire to match the FC, a totally solderless affair. BF4.3.1 set up was also a breeze. i did it indoors beside a window where it easily locked on to 5 satellites within the first minute after powering up. then i proceeded outdoors (minus laptop) to check goggle OSD and it very quickly locked onto 8 satellites within 30secs. it locked on to 17 satellites within +1min. i must admit the M10 must really be a world of improvement at a very tiny form factor.
short Q&A below:
1. rear top frame option affords the best and highest location on the quad. however this puts it in close proximity to the shortish vtx antenna. would there be any issues?
2. motor arm installation affords the best location away from the vtx if this were the major source of noise which may impede the module’s performance. but this puts it between the motor and caddx vista AU. any issues with this as well?
3. i plan to wrap the gnss module and the entire cable length with rubber shrink wrap tubing to protect from exposure and isolation from the carbon frame. is it acceptable to wrap the antenna with opaque rubber material? or should i use the included clear shrink wrap instead?
4. for added security, i also plan to strap the module with ziptie for good measure. from an OC perspective will this bit of nylon straddling across the antenna top affect its performance?
5. for the purist OC option i may still consider having a custom rear mounted TPU which will house the vtx antenna, gnss module and ELRS T-antenna in one install. should i just take this route? my main reservation with this is a rear impact crash puts the tpu assembly directly in harm’s way. not to mention the added weight.
looking forward to user feedback, wisdom and experience from the intofpv.com folks!
short Q&A below:
