Threads: 7
Likes Received: 4 in 2 posts
Likes Given: 0
0 I recently had my onboard SPI receiver go in my Eachine UZ65. I was looking at the spec sheet for the receiver and the operating voltage is 3.5V-10V. Before I take the time to squeak this little guy in is it going to drop out of the sky and failsafe when my battery hits 3.4? Anyone use one of these down to 3.1V?
Threads: 20
Likes Received: 490 in 341 posts
Likes Given: 420
20 I use XM receiver on my Mobula6HD and I haven't had any failsafe when the voltage dropped to low 3s Volt which is quite easy to do with the Mob6.
Threads: 125
Likes Given: 99
388 There is a 5V regulator on the FC. Even if the voltage is lower, the voltage is step up to 5v. So your receiver will still work as long as there is energy. But below 3V, your lipo will pretty much die off.
Threads: 7
Likes Given: 0
0 Thanks for the input!
Just incase somebody stumbles across this at some point, that flight controller does not support external FrSky receivers. There goes about 4 hours....
Threads: 7
Likes Given: 0
0 When I was trouble shooting receivers not working in BF I came across a video where they said make sure your FC supports your receiver. My manual says it supports external DSM2/DSMX and TBS crossfire. The BangGood website lists firmware targets for Frsky SPI, DSM2/DSMX, and TBS Crossfire receivers. I didn't see anything for SBUS, assumed that was my issue.
I soldered the receivers SBUS to the RX2 pad. Do I just solder to IR1 and run the FrSky SPI firmware?
Threads: 20
Likes Given: 420
20 03-Oct-2020, 02:18 AM (This post was last modified: 03-Oct-2020, 02:20 AM by jasperfpv.) As Snow pointed out, use the IR1 for Frsky XM receiver and turn on serial RX on UART 1 on the BF Port tap and then choose SBUS on configuration receiver setting.
SPI is for built in receiver, the exact thing you are trying to avoid/fix by adding an external receiver here.
Threads: 172
Likes Received: 2,297 in 1,844 posts
Likes Given: 4,753
103 i would go for the r-xsr receiver as it is small like the xm, but has a better range. sure the size of the xmplus wont be a true issue...
