Threads: 2
Likes Received: 0 in 0 posts
0 So I recently bought a new flight controller and it won’t flash. I have a xilo stax f4 flight controller and I tried to flash it on beta flight with the stm32f405 firmware but it said it failed. I looked up other ways so I downloaded the drivers and the zadig program off of betaflight and that doesn’t work either. What should I do??
Threads: 125
Likes Given: 99
388 You should try Impulserc driver fixer first. If this does not work, then follow below.
If you are downloading Zadig, I assume you are using Windows. When you boot into bootloader mode, what device populates in the Device Manager.
Threads: 2
0 I haven’t tried impulserc yet but to answer your question it loads up my oculus stuff, keyboard , mouse and a flash drive
Threads: 125
Likes Given: 99
388 I think you misunderstood. When you plug your FC into the computer, under the device manager windows, a new device will populate. When you plug the FC in bootloader mode, a different device will populate. I want to know that device is. It will either listed under the Port or USB tree. I am trying to see if you have the proper driver.
Threads: 2
0 Also impulse driver didn’t work. It just searched for a fc for 10 minutes.
Threads: 2
0 I’ve re-downloaded all of the drivers from beta flight and still doesn’t show
Threads: 125
Likes Given: 99
388 I have been asking you what actually populates in device manager when you plug in your FC in regular and in bootloader mode.
Threads: 2
0 Nothing comes up that says stm32
Threads: 125
Likes Given: 99
388 Can you at least tell me actually shows up?
Threads: 2
0 It’s a xilo stax f4 flight controller got it on getfpv
I am using the bind button it’s located next to the USB port
And when it’s not in bind mode the colors are red green and blue all three. And in bind mode just red
Threads: 2
0 Problem resolved I used a different usb thanks all lol
