Flight Controller cannot power on with USB but motor 5V pins
if your FC doesn't power on with USB cable, but works with the 5V pins on motor pins... what could be damaged?
Responses from MI Group:
Could be the diodes on the top left of this schematic, If it isn't the connector? its almost always the bat54c diodes.
Possibly the usb welds came loose? If you have a heat gun see if reflowing the welds works. Depending on the fc the usb can be a weak point.
I had the same thing but the other way around.. Just tossed it and installed a new one
Could it be the USB cable?
the same problem - my fault was to solder leds (and buzzer) to 5V rail on fc -- found schema in google Sad - after plugging the USB cable fc starts beeping, after switchinng off USB_BEEPER fc stops booting - on lipo works/booting ok ...
  JHEMCU GHF745 HD AIO F7 OSD Flight Controller and Built-In 40A BLHeli32 3-6S FC husafreak 0 73 Yesterday, 01:11 AM
Last Post: husafreak
  Semi Newbie here - T-Motor F7 Pro Full Function Tonestire 9 1,441 19-Feb-2024, 07:23 AM
Last Post: MontyFPV
  Help No response flight controller with receiver Crazyart 1 263 09-Jan-2024, 12:53 AM
Last Post: Crazyart
  SpeedyBee F405 power and UART Q husafreak 9 722 22-Dec-2023, 05:48 PM
  General question about FC 5V power supplies husafreak 4 286 05-Dec-2023, 04:57 AM
