12-Dec-2023, 12:28 AM (This post was last modified: 14-Dec-2023, 10:11 PM by drumgod. Edit Reason: Corrected BF version number. )
I've been working on dragging my gear forward to the latest BF and ELRS versions. This FC is doing something I've not seen before. It's a betafpv F4 1S AIO 12A elrs 2.2 (build here) and I have downloaded the latest firmware from betafpv's site: BF4SX1280 4.4.2_M85_A_ELRS v2.2_ELRS 3.0_20230202.hex
When I "auto detect" the quad, BF identifies it just fine. I load the local firmware file and BF shows it is loaded in the bottom left. I click the flash button, it greys out, and that's it. The FC seems to reset but no flash happened. This happens with 10.9.0 on both linux and windows, with firmware downloaded separately by each OS but from the same, official source.
Any ideas? Is there a log I can check for a clue as to what's actually happening?
lol. I'm hoping the answer isn't "disconnect the vtx", because I'll have to pull the top plate off and the stack apart to get to the solder points. Besides, it's been a reliable build so far and I'd prefer not to futz with it. Thanks guys!
