Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 hello is there anything at the market that i could connect battery and motor and NO FC and it would spinn this motor at full speed? or 50% speed? withoud any FC? i woild like to make something else from my biten motor, have idea for grass cutter xD but would need to power this motor/esc by button withoud any FC etc? does someone have an idea on esc like that? thanks and regards ! • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 10-Aug-2022, 07:18 AM (This post was last modified: 10-Aug-2022, 07:23 AM by Lemonyleprosy.) You can wire an esc to a servo tester and use that to control your motor speed. (You can use a lipo to power if desired rather than the power supply he used in the video) It’ll be variable speed, but you can set it to 50% or 100% or whatever fits your need. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 If you can generate a PWM signal through a potentiometer and maybe something like an arduino it should works directly without an FC. • Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 i was thinking aboud arduino but was not shure if it is easiest solution servo tester will be best for this - i didnt known of such device before ;P thanks and regards • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 10-Aug-2022, 08:17 PM (This post was last modified: 10-Aug-2022, 08:17 PM by Lemonyleprosy.) I’d be curious to see what you’re building as well as how it works out. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 14-Aug-2022, 07:08 AM (This post was last modified: 15-Aug-2022, 08:31 AM by d00lar.) small update this servo tester is 3s is there such for 6s ;s i have 6s battery and 6s motor so want use that ;P if no tehen some voltage reg ? 6s>3s? • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 I’m not 100% sure what you’re asking, so I’m going to answer what I think you’re asking, please correct me if you’re asking something different. If something says it’s rated for 3-6s, it means it can handle 3s to 6s batteries. HOWEVER, since we’re talking about a servo tester, I think you mean that it can handle 3-6v (3v to 6v). If your esc doesn’t have a 3 wire signal lead (5v, ground, and signal) in addition to the main power wires, then you could connect one of the bec’s linked below to your main power wires, run the 5v output to the servo tester, and run the signal wire from the servo tester to the signal wire on your esc. https://www.mateksys.com/?portfolio=mbec6s Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 16-Aug-2022, 06:02 AM (This post was last modified: 16-Aug-2022, 06:03 AM by d00lar.) this servo tester is 3s * i messed up the quastion this servo tester is 3s is there such for 6s ;s i have 6s battery and 6s motor so want use that ;P if no then some voltage reg ? 6s to 3s? • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 16-Aug-2022, 07:13 AM (This post was last modified: 16-Aug-2022, 07:23 AM by Lemonyleprosy.) See my previous answer. All the servo tester is doing is putting out a pwm signal to tell the esc how much power to put to the motor via a 5v pulsed signal- as long as you’re not putting too much voltage through the servo tester itself (in other words, use the linked to bec to power the servo tester), it doesn’t know nor care what size battery or amount of voltage/amperage is running through your esc or motor. It is strictly a control signal- it is taking the place of your throttle stick on a transmitter. Your transmitter doesn’t know or care what voltage or amperage is running through your quad- it just transmits “power equals 0% to 100%” depending on its value. Servo tester is the same. Does that make sense or am I not explaining it well? Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 ok to be clear https://aliexpress.com/item/4000902978297.html this is 2-6s and https://aliexpress.com/item/32850817335.html this is writen 4,8-6v and this will work even with my 6s batteries because this esc/bec is lowering this voltage on this 3pin cable that goes to this servo teaster yes? • Posts: 4,078 Threads: 77 Likes Received: 2,550 in 1,859 posts Likes Given: 3,955 Joined: May 2021 Reputation: 121 16-Aug-2022, 10:27 AM (This post was last modified: 16-Aug-2022, 10:37 AM by Lemonyleprosy.) Correct. The esc that you linked to has a bec that puts out 5v to 5.5v on that 3 pin cable depending on what amperage model you have- the servo tester can handle up to 6v, so regardless of which of those esc’s you have, the servo tester will be fine. The 50A and above models of that esc are the only ones that say they can handle 6s batteries, so make sure you have that model or higher in order for your esc to be able to handle your battery. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 ok bought 50a version will update some day what will be finished product ;d |
